crashed mz1000s need help
PostPosted: Sun May 10, 2015 5:51 pm
by dashti
hi
i have crashed mz 1000s has only 1000km
this photo for it
http://im55.gulfup.com/fkCaM9.jpg
http://im55.gulfup.com/U8xzCq.jpg
http://im55.gulfup.com/hs4vMX.jpg
http://im55.gulfup.com/dsPVMx.jpg
how can i change the battrey and start the bike ?
engine and gearbox and the radiators is ok
i just lost the key how to start it and need to change battrey
Re: crashed mz1000s need help
PostPosted: Sat May 16, 2015 11:26 am
by MJ310
Without a key you are going to struggle. To get to the battery first you need to use the key to unlock the rear seat, take it off and find a little pull ring behind the front seat, pull this and it will release the front seat, take it off. Next undo the two retaining bolts at the front of the tank behind the headstock, its a fiddly job so take your time, with them out you can lift the tank back on it's hinge so it's upright and there is the battery. Make sure you remove the earth first and if it needs to be replaced buy the best one you can as these bike need a decent high current battery. If you need more help just ask, where are you from?
PostPosted: Tue Jul 21, 2015 10:54 am
by boilermaker
MJ Is correct you need a battery with the highest "Cold cranking Amps" that you can get within the original spec.
