125 oil pressure
125 oil pressure
Postby bufallobiff » Mon Jul 14, 2008 9:47 pm
Just got an '01 w/ less than 2000 miles on it. The bike is in great shape outwardly and I have no reason to think that there is a major problem, however.... After cleaning it up and lubing the chain, I decided to set the idle to 1800 as it was at 3000.
I now find the oil light coming on and staying on below 3000. I would like to change oil and filter but I can't get a filter locally. I've read that the BMW 650 filter will work but my brother, who also owns an RT 125, says it doesn't fit. I've also read that there is a screen that needs tending to as well. I can't imagine that I don't have oil pressure as much as I've ridden the damn thing but I'm tempted to put a guage on it and see for sure. Where is that pesky sending unit and have you heard of problems with them? Any help would be appreciated.
bufallobiff
Re: 125 oil pressure
Postby DAVID THOMPSON » Tue Jul 15, 2008 9:45 am
there is a check ball and spring held in by the right side case if it is dirty can cause seat of ball bearing and ball need cleaned
change filter k and n 151 other brand hf or lf 151
use a shell rotella t 20w50 0r 40 oil
also pressure switch may need replaced
recommend oem replacement but
article in my space with a whole list
of them read my blog
its down the page a bit
spring behind ball may need replaced
part numbers for ball and spring
and how to do on request
pm me dave
Users browsing this forum: No registered users and 49 guests
