(Another) TS250 timing question
Postby NVA250 » Mon Jul 29, 2019 4:56 pm
Evening all,
I'm making slow and plodding progress with my TS250 restoration (viewtopic.php?f=5&t=9001) but I am nowhere near where I would like to be with it. Life gets in the way...
I wonder if someone can give me some advice regarding timing? The engine is the old 4 speed type with the finned head and angled spark plug hold which has complicated matters a little. I have worked out and marked off TDC, but all of the manuals that I have (original MZ and Haynes) give the BTDC timing settings in cm/mm measured through the spark plug hole or using the MZ gauge on the flat head supa 5 engine. Can anyone tell me what the correct timing should be in degrees if I'm measuring it using a 360 compass attached to the crank?
I think that it may be 21° or 22° BTDC but I cannot find anything / anywhere confirming this.
Any help would be greatly appreciated as the timing is my big stumbling block at the moment!
Thanks T
1974(ish) MZ TS250 - ex East German Army
1989 Trabant 601 Kombi
NVA250
Re: (Another) TS250 timing question
Postby Guesi » Tue Jul 30, 2019 12:28 am
22" 15` is the right timing.
Guesi Motorradteile
MZ spare parts
Postby Blurredman » Tue Jul 30, 2019 2:52 am
How easy is it to whip the head off and adjust thusly?
Postby Puffs » Tue Jul 30, 2019 5:08 am
Good point.
If it has the same stroke as the ETZ250, 22° 15` = 22.25° = about 3mm bTDC; see download/file.php?id=4847
Postby NVA250 » Sat Aug 03, 2019 3:21 pm
Super, thanks for the swift answers. I was considering taking the head off, but it's a fair bit of hassle rather than just working out (or knowing) the degrees
NVA250
Users browsing this forum: No registered users and 196 guests
