Case halves sealant oil pressure oil gallery
Postby curlybob » Sat Feb 22, 2020 9:45 am
In assembling the 660 cc crankcase, there are conflicting messages between service manuals out there.
Mz says, keep Yamaha Bond away from the oil galleries.
Raptor 660 (Yamaha) says, put sealant around the oil passageway.
I followed Mz and left the oil passage dry (no sealant) inside the case; will I have problems with oil pressure?
Would anyone know if the oil passage centered in the case halves is low or high pressure?
curlybob
Re: Case halves sealant oil pressure oil gallery
Postby Puffs » Sun Feb 23, 2020 6:14 am
Postby curlybob » Sun Feb 23, 2020 10:12 am
Good idea on checking my oil pressure. I have plans to crack the bleeder screws in hope of oil flow up top, etc.
I have made attempts to read the drawings, but did not have luck with determining the flow direction; which is why I asked.
That gallery/jacket is pretty big to be upstream don't you think? That would be a lot of volume to push by the look of it yah?
Anyway, I do not know for sure.
From the Raptor manual.
curlybob
Postby Puffs » Mon Feb 24, 2020 5:27 am
Postby curlybob » Mon Feb 24, 2020 12:26 pm
Thank you for the reply.
curlybob
Users browsing this forum: Google [Bot] and 156 guests
