Page 3 of 7
Re: Skorpion substitute part database- please add!
PostPosted: Thu Nov 20, 2014 1:10 pm
by Srinath
zippy49 wrote:Anyone know of a substitute part for the Traveller's rear view mirrors? Or at least something that would fit?
I'm not sure about the thread, but try napoleans or emgo's tha tare meant to fit a GS500.
When in doubt use GS500.
Cool.
Srinath.
PostPosted: Thu Nov 20, 2014 2:14 pm
by DAVID THOMPSON
Member hb7 sells mirrors
look for www moto-sience .com
i think thats it
got a nice set for the rt125 that fold up so i can get in the shop..
PostPosted: Fri Nov 21, 2014 12:37 pm
by zippy49
I guess I need to point out that the Traveller has a full fairing... Handlebar mount mirrors do not match what's on there at all.
PostPosted: Fri Nov 21, 2014 6:24 pm
by billr
zippy49 wrote:I guess I need to point out that the Traveller has a full fairing... Handlebar mount mirrors do not match what's on there at all.
I have a Traveller with a set of mirror/signals from hb7.
Front view of the set up
These are a bit longer and I see more road and less elbows... :lol:
Look for something with a 40 mm bolt spacing.
Bill R
PostPosted: Sun Apr 05, 2015 2:36 am
by tigcraft
BUMP
PostPosted: Tue Apr 07, 2015 9:28 pm
by Dicer
Hydraulic rear brake light switch for Skorpion Tour (maybe others) is Aprillia #81244679. Thread is 10x1 mm. I bought mine from A1 Racing. There are cheaper ones that will fit but the electrical connections would need changing. This one is a straight swap.
PostPosted: Mon Apr 13, 2015 1:27 pm
by Kcfirebolt
Anyone know of a replacement for the chain slider (rubber pad that runs along the top front of the swing arm)?
Thanks,
Charles
PostPosted: Mon Apr 13, 2015 3:45 pm
by DAVID THOMPSON
replace with a flat piece of serpentine belt from a car i find junk pieces all the time at my auto mechanic shop
PostPosted: Mon Apr 13, 2015 3:55 pm
by Kcfirebolt
Would you glue it to the frame with JB Weld or something similar? One suggestion I received was to find an old Delrin cutting board, cut a strip and JB Weld it to the swingarm. I thought I might be able to safety wire it (drill holes along the bottom) as a backup fastener (in case the glue gave way).
PostPosted: Mon Apr 13, 2015 6:25 pm
by DAVID THOMPSON
you will need to get creative
i have a bunch of bikes that are OLD and my DAD left me a very old machine shop... so doing it my way may not be best :D
PostPosted: Tue Apr 14, 2015 8:57 am
by MZCountryRider
Kcfirebolt wrote:Anyone know of a replacement for the chain slider (rubber pad that runs along the top front of the swing arm)?
I made one out of Tivar (UHMV polyethylene) for my Cagiva Elefant. Used cardboard to make a pattern first, transferred that the the sheet of Tivar, cut it out on the bandsaw and drilled the mounting holes. Easy to bend around the swingarm. Fit perfectly and works fantastic. After 350 miles, there's not a mark on the Tivar, even though the chain drags across it regularly.
PostPosted: Tue Apr 14, 2015 9:11 am
by Kcfirebolt
Would it be possible to take a picture and post/email it to me?
charleswmillerjr at
gmail dot com
PostPosted: Tue Apr 14, 2015 1:37 pm
by Kcfirebolt
I've ordered a foot long piece of Tivar from Ebay. Should be here in a few days. Thanks. Still would love to see a pic of your set up.
PostPosted: Thu Apr 16, 2015 8:52 am
by MZCountryRider
A couple of photos when I was making the guide for the Elefant.
Made a cardboard pattern:
Covered the Tivar sheet with masking tape and transferred the pattern to it:
Cut out on the bandsaw, mounting holes drilled and installed:
PostPosted: Thu Apr 16, 2015 11:28 am
by Kcfirebolt
Thank you for the images!
