Page 3 of 3
Re: MuZ ManX project
PostPosted: Mon Mar 28, 2016 4:38 pm
by edfmaniac
I should mention that I use a LiFePO4 Shorai battery and cold starting becomes difficult below approximately 60 degrees F. It will start, but I have to pull a load on the battery a few times to get it's internal temperature high enough to provide the amps required to turn the engine over fast enough to fire. Once everything is warmed up, or if the ambient temp is high enough, starting is no problem. I used the same battery that goes in the KTM 690, which suffers from the same problem in colder temps, but Shorai recommends the next larger model if you consult their website in regards to our motor(Raptor 660).
I wanted to delete the cross member just to lose more weight, but I'm scared. :lol:
PostPosted: Mon Mar 28, 2016 9:00 pm
by DAVID THOMPSON
my basic comment on batteries is " i have never seem a bike that did not need a bigger battery
or a bigger battery box ...or BOTH"
PS never add any thing to the system that you do not need that uses more electric
Re: My new to me MuZ ManX
PostPosted: Thu Dec 08, 2016 12:48 pm
by dandywarhol
Hajok wrote:My blog Muz Manx is now in english... at least the most recent posts are. I'm translating older posts as well, but it takes time.
So, from now on it is more than just pictures... and hopefully it is interesting to read as well
Thank you for the translation service - inspirational stuff and giving me plenty of ideas 8)
