1998 Skorpion Radiator Cap
Postby oldbiker1 » Sun Mar 24, 2019 10:41 pm
I desperately need a rad cap for my Skorp!! Ive had the cooling system pressure checked today and after more than 20psi pressure in there it was found not leaking! Bonus! BUT the cap is very 2nd hand and not sealing very well. I was told we use a Yamaha Engine, Yes, but no Yamaha listing is available for the cap.
Could someone advise me where to buy one in Australia please? Or will I have to get one from Grahams in the UK? Nothing cross references to ANY Yamaha part. I spent 20 minutes with the local parts fellow today trying ANY listing.
oldbiker1
Re: 1998 Skorpion Radiator Cap
Postby DAVID THOMPSON » Mon Mar 25, 2019 10:31 am
ktm dealer 1.1 bar = 15/16 lb
or a tractor shop in au
Postby oldbiker1 » Mon Mar 25, 2019 4:52 pm
thanks David. Ill get to a KTM dealer today..just hope the dimensions are right at the shop!
oldbiker1
Postby oldbiker1 » Tue Mar 26, 2019 12:21 am
1.1 bar dont exist!! best is either a 1.0 bar or 1.4 bar!!! this is getting very annoying! Might swap the neck of the rad over to a generic one to get a common cap!
oldbiker1
Postby DAVID THOMPSON » Tue Mar 26, 2019 8:37 am
1. bar is close at about 15 lb
Postby oldbiker1 » Wed Mar 27, 2019 3:54 am
closest in OZ going by the dimensions is:
KTM 65SX 1.4 Bar...A$30 will do for now. Ill chat to an alloy welder to put on a generic neck so I can use a common rad cap.
oldbiker1
Postby Puffs » Wed Mar 27, 2019 5:13 am
A cap acting as a 1.4bar (= 20psi) safety valve (as opposed to 1.1bar = 16psi) will increase the temperature at which it will start to blow-off. This is desirable for enduro bikes, KTM's heartland, as for several tough climbs you cannot make any speed, while you have to work the clutch a lot. Lacking cooling, the engine temperature increases. If the bike starts to cook & you loose your coolant, you're done.
For a road bike, a higher pressure seems a bit pointless, but I'm not sure it can do any harm either.
Postby oldbiker1 » Wed Mar 27, 2019 5:23 am
yes I was wondering about that. I asked the rad experts and they assured me the 0.2 bar shouldnt be a problem
oldbiker1
Postby oldbiker1 » Mon Apr 01, 2019 1:04 am
well the KTM 65SX radiator cap fitted well, no more leaks so far. Ill keep an eye on the coolant level.
oldbiker1
Users browsing this forum: No registered users and 117 guests
