Re: funky Choke on a 125 SM
Posted:
Sat Feb 25, 2017 3:21 pm
by DAVID THOMPSON
seatbolt location
there is a bolt in bottom of seat right about over center of the rear tire
it is item number 4in the attachment
http://www.grahamsmotorcycles.com/web/S ... M_SEAT.htm
Posted:
Mon Feb 27, 2017 3:21 am
by Rockybal1
Thanks for your help.
Many thanks
Posted:
Mon Feb 27, 2017 3:25 am
by Rockybal1
Many thanks
Could you tell me if the mx 125 sm has a automatic choke I can't find it ?
Posted:
Mon Feb 27, 2017 8:31 am
by DAVID THOMPSON
its a twist unit on the left handle bar grab that handle bar with your hand
and your thumb can find it it is between the rubber grip and and the switches
Posted:
Mon Feb 27, 2017 5:40 pm
by stephendacosta
There is a dzus fastener above the rear tire on the under side of the fender. turn it counter clock-wise(may stay with the fender or come out. also may have been replace with a bolt by previous owner). Once it is loose, pull the seat to the rearward to disengage from two tangs; one at front and one at rear of seat.
