Short intro - RT 125 owner
Postby FlyingRt » Thu Oct 08, 2015 2:53 pm
Hi all,
when searching for information about the small 4 stroke MZ I found your very informative forum. I am from Southern Germany, drive a 1986 BMW K75S and since 2 months, a 2003 MZ RT 125. Whereas there is a very active German forum for the BMW, there is only a small community of MZ 125 (4 stroke) drivers.
I bought the MZ in a rather neglected condition with 22000 Km on it. Optical its ok, but services seemed not to have been done regularly, e.g. the oil filter was from 2004 (the production year is stamped on it, but of course I might have been changed later), air filter form 2007 and the front tire was still the original one from 2003. I changed all liquids, all filters, disassembled and cleaned the carb, changed several O-rings and the float assembly in the carburetor, also changed the cam chain (which was very worn and already acted as a saw, almost cut the oil channel), the free wheel drum, cleaned all electrical connections, controlled and adjusted the valves etc.. Now it is running more or less good, not as fast as I though, not as economic as it should, but reliable. But I am optimistic to find in this forum possible solutions for future problems.
Martin
FlyingRt
Re: Short intro - RT 125 owner
Postby DAVID THOMPSON » Thu Oct 08, 2015 4:35 pm
i have 22,000 miles on one good luck it will grow on you
i have also r50s 1963 title and a 1953 r51/3
and i lurk here often
DAVE the site moderator
also other nice toys
Postby stephendacosta » Thu Oct 22, 2015 5:22 pm
And I have ten of the 125 four strokes. Where did you get parts? There is a rumor that a former MZ employee is getting parts from suppliers to sell. Are you in a position to explore this? I have so many 125's to insure a parts supply. --Steve
Stephen DaCosta
stephendacosta
Postby therealche » Mon Oct 26, 2015 4:54 pm
This lot have a lot of spares for them
http://www.muz.de
And try Guesi
https://www.guesi-motorradteile.de
therealche
Postby FlyingRt » Fri Sep 01, 2017 2:53 pm
2 years and 9000 Km later: Still running! :D
Martin
FlyingRt
Postby DAVID THOMPSON » Fri Sep 01, 2017 6:34 pm
feed it lots of clean oil and keep an eye on the timing chain tension
Postby FlyingRt » Wed Oct 24, 2018 1:23 pm
Sold it (already in June) after 11000 Km very reliable km! (Totally 33000 Km.)
It was replaced by a BMW R1100R (build in 1998, 72000 Km).
Bye
Martin
FlyingRt
Return to 125 cc
Users browsing this forum: No registered users and 38 guests
