Skorpion wrote:Hi.
The ETZ300 timeing is set at 2.5 to 2.75mm.
You check the squish band clearance using strip of 2mm solder inserted through the plug hole, when compressed by the piston you need it to measure 1.0-1.2mm,
check in more than one place around the piston crown.
Users browsing this forum: No registered users and 46 guests
