Page 2 of 2
Re: Mikuni VM30 ?
PostPosted: Sun Jun 02, 2019 11:02 am
by akirasan
When i got my ETZ last year and rode it 30 miles home it was surging on the over run like a bucking bronco.
So I turned the tickover up and changed the standard airfilter for a K and N in the airbox
I bought a panel filters and bent it to fit round inside the air box.
No more surging with the standard carb.
Mikuni VM30
PostPosted: Sun Jun 02, 2019 11:48 am
by burudi
high flux air filter round, the same but inexpensive at alliespress.
http://mzclub.forosactivos.net/t1409-fi ... z-250#7246
Re: Mikuni VM30 ?
PostPosted: Sat Jun 08, 2019 9:50 pm
by philt77+
The settings determined by Derek Pickard were
150 main jet
6DH3 needle mid-notch
P-5 needle jet
2.5 slide
Pilot jet 30 or 35
These settings take into account the comments from arthurf
If in Australia you can get the Mikuni VM30 plus the MZ kit for about $200 from MikuniOz. About 110 quid. This is probably cheaper than a genuine Bing or genuine NOS BVF if you can find one.
Re: Mikuni VM30 ?
PostPosted: Sun Jun 09, 2019 6:59 am
by burudi
thks philt77+ !
Re: Mikuni VM30 ?
PostPosted: Sun Jun 30, 2019 5:57 pm
by dirtsurfer
arthurf wrote:Dear All, Recently I have been speaking with Derek Pickard (out here in Oz), and he mentioned that his article on the VM30 had one error - the size of the pilot jet - it should be 30 or 35, not 40.
Now however I cannot get onto the "Realclassic" site to write down the specifications/jetting/and conversion process and would like a bit of help from all/any of you in this area.
My BVF carb is quite worn (the slide can be "rattled" from side to side within the carb), and occasionally sticks and does not return the carb to "off'''.
So I am looking at using a Mikuni. Which Mikuni model has the spigot mounting (so that I can use the existing manifold)? Can anyone supply pictures of changes to both the manifold and the air box connections?.
Many thanks, Arthur :smt007
Hi Arthur
The spiggot mounting model is: VM30-83 30mm Mikuni VM Carburetor - $143.00 from MikuniOz
You can also get the jetting and needle kit : VM30-83 Mikuni Tuner Kits for 2-Stroke Engines - MZ '84 ETZ 250 for a few dollars more
I wound up buying a twist grip and cable as well.
I don't have pictures, but to mount your mikuni, you will need to reduce the O/D of the MZ manifold slightly (I used fine grit abrasive paper) and increase the I/D of the airbox connection (I used a stanley knife) If your airbox rubber is old and hard, you may have to soften it up in hot water or pay $3 for a new one
good luck
Max
Re: Mikuni VM30 ?
PostPosted: Mon Jul 01, 2019 5:53 am
by burudi
alibaba (and the 40 thieves) is full of bing carburetors and BVF as well as the extinct front brake pump. EVERYTHING is Chinese copy!
Re: Mikuni VM30 ?
PostPosted: Tue Jul 02, 2019 3:53 am
by Puffs
Re: Mikuni VM30 ?
PostPosted: Wed Mar 04, 2020 1:26 pm
by burudi
I agree in opinion. With a Chinese 35 I am doing very well.
thanks !
Re: Mikuni VM30 ?
PostPosted: Wed Jun 21, 2023 10:49 am
by klemmy
philt77+ wrote:The settings determined by Derek Pickard were
150 main jet
P-5 needle jet
2.5 slide
Pilot jet 30 or 35
pretty old topic, but anyway...
Is it possible to get 2 stroke kit from Mikuni somewhere in Europe?
Re: Mikuni VM30 ?
PostPosted: Wed Jun 21, 2023 10:52 am
by burudi
yes.
deutchland mikuni
uk mikuni.
Re: Mikuni VM30 ?
PostPosted: Thu Jun 22, 2023 9:54 am
by klemmy
They dont offer 2 stroke kits, only spare parts separately. The main question is what jets are in these https://www.guesi-motorradteile.de/inde ... ing=mikuni and which they should be for ETZ 250. There is only main jet (150) and idle jet (45). In this configuration my bike is running like a crap.
Re: Mikuni VM30 ?
PostPosted: Thu Jun 22, 2023 10:36 am
by burudi
error-error-hit-error-hit......
I think more than one is affected by the heat
