EZT 250 - Hows yours running....
Postby Andy_C » Sun Aug 27, 2017 8:56 am
Had my latest ETZ for over a year now, and it just seems to get better and better.
it was prettty rough when I bought it but after lots of fiddling / fettling it runs really really well.
I never ceased to be amazed at how eager it is to rev, in fact it seems to like being ridden hard - the more revs the better.
Also found that it runs better on unleaded rather than super unleaded.
Been riding it a lot lately.
Oh and meant to have said I am running a 1 tooth smaller than standard gearbox sprocket - all my riding is done 1 up.
Andy_C
Re: EZT 250 - Hows yours running....
Postby Mintonly » Wed Mar 14, 2018 12:13 am
:o wow that is great for you enjoy and keep riding :D
Mintonly
Postby Blurredman » Wed Mar 14, 2018 7:49 am
I'm 1 tooth less at the front on my rebuild machine. The machine itself is still running in, but sometimes I can really feel that it is settling.
Compression must be really high as the bike occasionally starts up backwards when the start up has been finicky (cold etc), but re-starting normally sorts that out. The timing is actually set around 10 degrees before TDC so it is not the timing. It broke my tacho cable :( :lol:
Postby Guesi » Thu Mar 15, 2018 12:44 am
10 degrees is not correct.
MZ says 22 degrees.
Or 2,6 mm before TDC.
That is why your engine starts backwards....
Guesi Motorradteile
MZ spare parts
Postby Blurredman » Thu Mar 15, 2018 3:29 am
Guesi wrote:10 degrees is not correct.
MZ says 22 degrees.
2.5mm before TDC is 30 degrees before TDC for me. That makes it run backwards 80% of the time and even switches whilst running. 1.5mm before TDC is 22 degrees and that makes it run backwards too.
Postby Guesi » Thu Mar 15, 2018 3:39 am
This is what the german manual says:
Ignition timing: 3,0-0,5 mm before OT = 22°15'-2° Kurbelwinkel
Guesi Motorradteile
MZ spare parts
Postby Blurredman » Thu Mar 15, 2018 3:47 am
Guesi wrote:This is what the german manual says:
I know, I have looked into it a lot. But doen't work for me. :smt006
I have a timing light with a degree offset and 22 degrees was 1.5mm before top dead. (for me..) :lol:
Postby Puffs » Thu Mar 15, 2018 6:41 am
Following a moderator choice that is IMO biased and flawed (someone posting aggressive personal attacks is rewarded, while my technical posts are removed), I have withdrawn from this forum.
Postby Blurredman » Thu Mar 15, 2018 7:31 am
Thank you for the diagramme, Very insightful !
