4 speed TS250 engine rebuild
PostPosted: Sat Feb 10, 2018 9:35 pm
by NVA250
Hi all,
I'm going to have another go at my TS250 engine in the next couple of weeks. I'm going for a full rebuild so will be splitting the crankcase. The MZ manual says you need a special tool for this that essentially looks like a sheet of folded metal with holes in. Do you actually need this or can it be done without it?
If anyone has experience of splitting the crankcase before then any advice would be appreciated!
Cheers now! T
Re: 4 speed TS250 engine rebuild
PostPosted: Tue Feb 13, 2018 12:27 am
by Guesi
It can be done without it. But using this tool makes it much easier to split...
But what you need for 100% is the clutch extractor.
PostPosted: Tue Feb 13, 2018 3:27 am
by Blurredman
Indeed, as Guesi says, It primarily allows a equal case splitting application and leverage to do so.
PostPosted: Tue Feb 13, 2018 1:24 pm
by Guesi
It allows more, for example pulling in the crankshaft of if stucks halfway in the crankcase .Or pushing it out of the crankcase etc.
You can see it on the MZ videos on youtube
https://www.youtube.com/watch?v=e71KJeBD76Y
PostPosted: Thu Feb 15, 2018 4:37 pm
by NVA250
Thanks, I think I'll give it a go without the special tool. I have no doubt that there'll be problems!
I finally have the correct (I hope) clutch puller...
