MZ TS250 neutral detent bearing HELP!
Postby NVA250 » Mon Feb 26, 2018 6:26 pm
Evening all,
I'm in the slow process of putting my TS250 4 speed engine back together. The engine was partially dissembled when I got it and I've discovered a small, but important part is missing.
On the underside of the engine there is what looks like a second oil drain plug, but this is spring loaded and should have a ball bearing at the top which acts as a neutral detent (whatever that is!). I have the spring and the nut but no ball bearing, I can only assume that the last owner has lost it. I think it's just a ball bearing that I need, but what size? I have been told by Martin from Burwins motorcycles that he thinks it's 3/16. Does anyone know it that's correct?
Thanks in advance Tim
1974(ish) MZ TS250 - ex East German Army
1989 Trabant 601 Kombi
NVA250
Re: MZ TS250 neutral detent bearing HELP!
Postby Guesi » Wed Feb 28, 2018 12:48 am
The diameter of the ball is 8 mm.
Guesi Motorradteile
MZ spare parts
Postby NVA250 » Thu Mar 01, 2018 8:39 am
Guesi wrote:The diameter of the ball is 8 mm.
Great! That works out as 5/16 I think so I must have misheard 3/16 (imperial was never my strong point!). I've ordered an 8mm bearing so will see how that fits
NVA250
Users browsing this forum: No registered users and 74 guests
