DAVID THOMPSON wrote:the relay 19 problem if relay 19 not on or its contacts bad then cdi box not getting power
this can also be a bad side stand switch or kill button
DAVID THOMPSON wrote:NOTE
1the kill switch on the right handle bar must be in the on position
2 the bike in neutral
3the sidestand up
then you will have 12v on both red/black and red/white at the relay contacts when the key is on
on my rt125 if it sets for a long time and carb dries out its a bastard to get started when the carb is dried out....
XCalsteRX wrote:I'm assuming you've tried a new spark plug? If so have you made sure the spark plug has a ground? If not put the side of the spark plug to the frame or engine, be sure not to hold the spark plug whilst doing this or wear some safety gloves otherwise you may get a 12 volt shock ha!
Trying to save you a hefty labour bill!
XCalsteRX wrote:Ahh okay, well I hope they find the fault! I also hope they don't charge you the earth for it to, be sure to let us know what it was if they find anything
