I have a 1995 Silverstar with the Rotax Engine. I believe it's the 504E. I need a new vavle cover gasket, gromit, and possible other little rubber pieces. ANnone have a good source for parts?
Thanks,
George
DAVID THOMPSON wrote:being its a race motor ...and dry sump = its going to leak some where
if its not leaking somewhere !! check the oil level cause its probably OUT
with effort you can tidy it up but its a work in progress
