Sprocket bearings..
Sprocket bearings..
Postby 95SaxonTour » Sun Feb 12, 2017 10:45 pm
Anyone know what the bearing number is for the rear sprocket carrier? It's for a 500 Saxon, but pretty sure that carrier is the same as the etz. I did this job before on my old Saxon. As memory serves, there are two bearings inside.. I think.
thanks,
Ryan
95SaxonTour
Re: Sprocket bearings..
Postby DAVID THOMPSON » Mon Feb 13, 2017 1:06 am
wheel 500r left click on picture to make bigger up in the picture numbers 6 is bearing 7sleve 8 is bearing 9 ?
Postby 95SaxonTour » Mon Feb 13, 2017 2:07 am
Thanks Dave, but I need the roller bearing numbers for the chain side. The two (I think) that are pressed into the piece that holds the sprocket
95SaxonTour
Postby DAVID THOMPSON » Mon Feb 13, 2017 1:54 pm
here
Postby 95SaxonTour » Mon Feb 13, 2017 6:16 pm
6004 bearing then..
Thanks Dave
95SaxonTour
Postby DAVID THOMPSON » Mon Feb 13, 2017 10:44 pm
the parts book for 500 frame and rotax engine is at www.muz.de
LOOK here
http://www.muz.de/ersatzteillisten.html
for these
Ersatzteilliste Saxon Modelle (5,7 MiB)
Ersatzteilliste Rotax-Motor (4,7 MiB)
DAVE
Users browsing this forum: No registered users and 128 guests
