PLEASE HELP :(
PLEASE HELP :(
Postby Braheem6942 » Mon Jun 18, 2018 4:54 am
Hi All ,
I have recently taken my bike to my mechanic and he has advised I need to replace a few items as there is a loud noise coming from my engine.
he has said it needs the following.
Cam Chain
Tensioner
full gasket set or at least the head and rocker.
I'm wondering if anyone can help please as I am finding it really difficulty to find these parts :(
thank you,
Braheem6942
Re: PLEASE HELP :(
Postby Puffs » Mon Jun 18, 2018 5:42 am
Hi Braheem,
best tell us what bike this is about.
Yes, if the cam chain in an OHC engine is worn beyond the adjustment range of the tensioner, it can get loud. And you'll loose power, as the valve timing will be off. Then the chain needs to be replaced.
The chain tensioners that I know hardly wear, and normally don't need replacing, but I have no experience with any MZ 4-stroke. Might be different.
You'll need to replace any gasket that is destroyed in the repair, no more. Often the rocker cover is sealed with a shaped 'O'-ring, which can be re-used. Only if the cylinder head is cracked or warped it needs to be replaced, but that is quite uncommon (and very costly). The manual will give specifications for the rockers, but those too normally last quite long.
Re: PLEASE HELP :(
Postby droy » Mon Jun 18, 2018 7:14 am
MZ year, cc, type please !!
Then we can help!
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Re: PLEASE HELP :(
Postby Braheem6942 » Tue Jun 19, 2018 4:05 am
Missed out a key bit of information there didnt I !! apologies
I have a 2007 - MZ SM 125
Braheem6942
Re: PLEASE HELP :(
Postby Puffs » Tue Jun 19, 2018 7:40 am
Looks like your SM 125 has the same engine as the modern RT 125. Have a look on eBay, where you will also find gaskets, or complete kits. If you can't find it in English, try German (Steuerkette).
The other thing you can do is look at:
https://www.guesi-motorradteile.de/inde ... Z_125/_/?_, looks like he has just about everything. And you can contact him (Guesi) via this forum.
Users browsing this forum: Bing [Bot] and 3 guests
