ISDT parts, bikes, etc
Postby 1sogdusm » Tue Dec 19, 2023 1:26 pm
Looking in the U.S. for ISDT parts, bikes, and anything associated with MZ ISDT. I am in need of a top end, cylinder, head, piston, rings for 90% bike I’m working on. I also need some carburetor parts, float, needle, gaskets, etc.
If you have any of the above please let me know.
1sogdusm
Re: ISDT parts, bikes, etc
Postby Guesi » Wed Dec 27, 2023 1:19 am
Hello
Pistons can be used from the "normal" ES250/2 models.
They can be adapted for the ISDT.
About 175 bottom end for the 250 ISDT... It should work, but as the 250 ccm piston is heavier than the 175 ccm piston, the balancing of the crankshaft is not the same which results in more vibrations if you use the "wrong" piston size.
Guesi Motorradteile
MZ spare parts
Return to Wanted
