Speedo
Speedo
Postby mzsrus » Fri Jun 03, 2022 12:25 pm
Hello
Any ideas
Speedo not work on my mz1000s
Everything else does-on start up the speedo moves as normal
Notused for ten years now
Sensor on back axle if it is that works fine
Checked on other 1000
Was areplacement speedo from Grahams
not actually used since full service and new clocks back in 2013
any ideas
new owner of Mz 1000s
mzsrus
Re: Speedo
Postby DAVID THOMPSON » Sat Jun 04, 2022 5:48 am
dirty contacts in wire harness
some of the plugs in my rt125 have been replaced with Anderson power poles
or soldered due to the quality of the plugs
the plug at the voltage reg just milted into a pile of junk
oh the fun of keeping an electric powered motorcycle running
Re: Speedo
Postby Puffs » Sun Jun 05, 2022 2:46 am
Re: Speedo
Postby MJ310 » Sun Jun 05, 2022 7:02 am
Can you use the clocks off one of your other bikes to see if it's a clocks/wiring fault? I know it's a pain to strip down but I think it will be your best bet. If you need a hand give me a shout.
MJ310
Re: Speedo
Postby mzsrus » Wed Jun 08, 2022 3:37 pm
Swapped sensors
Swapped clocks
Still everything works apart from Speedo
Frustrating
mzsrus
Re: Speedo
Postby MJ310 » Thu Jun 09, 2022 10:28 am
Looks like you might have a wiring fault, try disconnecting the plugs from the ECU and give them a good shot of contact cleaner and go through any part of the loom that might have an effect.
MJ310
Return to 1000S
