daytona992 wrote:Hi Ged,
Sorry you are still having problems. Have you checked all the earth points. I would remove each earthing point, thoroughly clean all contacts, apply Dialectric grease and replace. Over the years I have had a number of electrical problems and each time although not instantly obvious turned out to be insufficient earthing contacts. Modern electronics also seem to require perfect earthing points as they are operating at low amps.
Good luck. Regards, Gary.
cheers for the reply but it cant b the earths nor sidestand switch ,fuses relays,im pretty certain ,,,,,last thurs i rode my bike home ,it was running great ,in fact its the first time i gave it a big handful ,fast n stable i was impressed ,got home put bike in shed,,,,,friday took bike out of shed ,jacked up using abba stand ,changed front sprocket ,lubed chain,lifted tank ,changed air filter ,removed oil cooler brackets changed oil filter and engine oil ,using access from front of bike puting my hand over the radiator i removed coil retaing brack ,unplugged connectors ,carefully removed coils ,replaced plugs re fitted coils ,connected leads to coils ,then retaining brackets,turned on ignition ,pressed starter ,engine turning over but no start ,tried a couple of times ,removed plugs there soaking in petrol ,put old plugs back ,which as same effect,and the rest is history ,as you see i did nothing wrong ,dont know whats happened ,just cant see it being the earths or starter button ,as ive said one minute bike works ,then it dont ,
![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
banging my head against a brick wall ,wish there was a mz genius in lancashire
