by DrGonzo » Tue May 10, 2016 12:24 pm
I sent an email to Motion Pro. We shall see. Any other sources for Silver Star cables?
DrGonzo
by DAVID THOMPSON » Tue May 10, 2016 4:52 pm
EDIT see posts further down the page for more info
http://americandirtbike.com/and the cure a hydraulic clutch but not cheap
http://americandirtbike.com/magura.htmdave
- Moderator
by DrGonzo » Sun May 15, 2016 1:31 pm
Any advice on how to replace the cable. It looks like I will have to remove the timing belt and so forth to access the cable at the engine?
DrGonzo
by MZCountryRider » Sun May 15, 2016 5:00 pm
You should just be able to remove the plastic plug(s) (with screwdriver slot in them) on the clutch case and unhook the lower end of the cable.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
by DAVID THOMPSON » Mon May 16, 2016 10:38 am
- Moderator
by DAVID THOMPSON » Mon May 16, 2016 11:39 am
also here
- Attachments
- rotax clutch cable adj.pdf
- (348.79 KiB) Downloaded 504 times
- Moderator
by DrGonzo » Mon May 16, 2016 11:43 am
Thanks guys. I did figure it out and removed the cable. Now sending it to Motion Pro for a new one.
DrGonzo
Return to 500 cc
