Page 2 of 6
Re: gear lever availibility
Posted:
Wed Jun 11, 2014 3:33 pm
by handsomejackuk
Posted:
Wed Jun 11, 2014 4:08 pm
by Guido
Item number:-
201106496631
Sorry wasn't Ebay De , was ebay fr but item number should work from uk as it's available to European Union.
Regards Allan
Posted:
Wed Jun 11, 2014 4:14 pm
by Guido
That's actually the third different style of lever I have seen for a Mastiff!!
Allan
Posted:
Wed Jun 11, 2014 4:37 pm
by handsomejackuk
think its the same item... looks a bit shabby... i hang on to find a better one if i do !!!!!
have made one for now, and it seems to be ok... tried it out briefly tonite..
Posted:
Fri Jun 13, 2014 1:24 am
by breakwellmz
Oh to be back in the old workshop-Take the splined bit and join it to the lever at the length i wanted,easy!
You`re using a lever only without a linkage are you,how are you getting on with it?
I do wonder if we`re missing something here-Why is a linkage there if it isn`t needed?
What do other similar Yamaha engines use?
Posted:
Fri Jun 13, 2014 6:52 am
by den
would you like to commission me to make you one , you can have custom shape, measurements,what ever,,how much would you like to pay,,
Posted:
Fri Jun 13, 2014 10:16 am
by DAVID THOMPSON
standard pattern by law most areas is 1 down then 1 n 2 3 4 5 up
a straight lever results in 1 up then 1 n 2 3 4 5 down or a reverse pattern also called GP pattern
as rear sets reverse the shift
this motor because of the way its shift is made requires the reversing lever to get it to shift the way the law requires
for street use...
i made some good money when i was a kid making english bike conversions to get the shift and brake on the
proper side for usa street use the racers left them the english way
Posted:
Fri Jun 13, 2014 11:58 am
by den
whooo , had an idea,, lets go tiptronic,,do away with the lever altogether and have an up down button on the handlebar,gear position indicator aswell,, its not a new idea , there are kits already available,,
anyways,, the gear lever from a YAMAHA FJ1200 looks close,
Posted:
Fri Jun 13, 2014 1:35 pm
by handsomejackuk
den wrote:would you like to commission me to make you one , you can have custom shape, measurements,what ever,,how much would you like to pay,,
hi Den,
fiding neutral a bit hard to find, the lever i got is a bit of a home made affair at moment... but it will do until i find summut better...
Posted:
Fri Jun 13, 2014 4:32 pm
by Glidd
BA Bikes have a MZ 660 Baghira & Mastiff Rear brake lever on UK eBay for £38.50 or offer.
Posted:
Fri Jun 13, 2014 5:09 pm
by handsomejackuk
dont see a gear lever on there Glidd ?
are you sure ?
can you posst link....
Al...
Posted:
Sat Jun 14, 2014 6:26 am
by breakwellmz
DAVID THOMPSON wrote:standard pattern by law most areas is 1 down then 1 n 2 3 4 5 up
for street use...
Hi.
Am i being thick?
I`ve looked at this linkage again this morning.
If the lever is pushed up(Rotated clockwise),the splined shaft also rotates clockwise.Only if a lever was put on the splined shaft facing`backwards`would the shift pattern be reversed,
wouldn`t it?
Posted:
Sat Jun 14, 2014 7:02 am
by handsomejackuk
standard shift... if you put the lever on the splined shaft it is as normal same as any other XT600...
Posted:
Sat Jun 14, 2014 7:27 am
by breakwellmz
Thanks for that!
Not familiar with XT singles other than the one in mine.Presumably`ours`has a larger lump on the LH side compared to earlier XTs,otherwise you could just fit one of these-
http://www.ebay.co.uk/itm/310486519424? ... EBIDX%3AITIs this any help?-
http://www.wemoto.com/bikes/Yamaha/XT_6 ... ear_Lever/Cheers
Posted:
Sat Jun 14, 2014 12:12 pm
by DAVID THOMPSON
my traveller was modified so much by past owners it is probably not like any in the uk
?? and none to compare it with here..
