Skorpion substitute part database- please add!
Re: Skorpion substitute part database- please add!
Postby Srinath » Thu Nov 20, 2014 1:10 pm
zippy49 wrote:Anyone know of a substitute part for the Traveller's rear view mirrors? Or at least something that would fit?
I'm not sure about the thread, but try napoleans or emgo's tha tare meant to fit a GS500.
When in doubt use GS500.
Cool.
Srinath.
Srinath
Postby DAVID THOMPSON » Thu Nov 20, 2014 2:14 pm
Member hb7 sells mirrors
look for www moto-sience .com
i think thats it
got a nice set for the rt125 that fold up so i can get in the shop..
Postby zippy49 » Fri Nov 21, 2014 12:37 pm
I guess I need to point out that the Traveller has a full fairing... Handlebar mount mirrors do not match what's on there at all.
Tom in SoCal
zippy49
Postby billr » Fri Nov 21, 2014 6:24 pm
zippy49 wrote:I guess I need to point out that the Traveller has a full fairing... Handlebar mount mirrors do not match what's on there at all.
I have a Traveller with a set of mirror/signals from hb7.
Front view of the set up
These are a bit longer and I see more road and less elbows... :lol:
Look for something with a 40 mm bolt spacing.
Bill R
billr
Postby tigcraft » Sun Apr 05, 2015 2:36 am
BUMP
tigcraft
Postby Dicer » Tue Apr 07, 2015 9:28 pm
Hydraulic rear brake light switch for Skorpion Tour (maybe others) is Aprillia #81244679. Thread is 10x1 mm. I bought mine from A1 Racing. There are cheaper ones that will fit but the electrical connections would need changing. This one is a straight swap.
Clive in Central Florida
'96 Skorpion Tour.
Dicer
Postby Kcfirebolt » Mon Apr 13, 2015 1:27 pm
Anyone know of a replacement for the chain slider (rubber pad that runs along the top front of the swing arm)?
Thanks,
Charles
Kcfirebolt
Postby DAVID THOMPSON » Mon Apr 13, 2015 3:45 pm
replace with a flat piece of serpentine belt from a car i find junk pieces all the time at my auto mechanic shop
Postby Kcfirebolt » Mon Apr 13, 2015 3:55 pm
Would you glue it to the frame with JB Weld or something similar? One suggestion I received was to find an old Delrin cutting board, cut a strip and JB Weld it to the swingarm. I thought I might be able to safety wire it (drill holes along the bottom) as a backup fastener (in case the glue gave way).
Kcfirebolt
Postby DAVID THOMPSON » Mon Apr 13, 2015 6:25 pm
you will need to get creative
i have a bunch of bikes that are OLD and my DAD left me a very old machine shop... so doing it my way may not be best :D
Postby MZCountryRider » Tue Apr 14, 2015 8:57 am
Kcfirebolt wrote:Anyone know of a replacement for the chain slider (rubber pad that runs along the top front of the swing arm)?
I made one out of Tivar (UHMV polyethylene) for my Cagiva Elefant. Used cardboard to make a pattern first, transferred that the the sheet of Tivar, cut it out on the bandsaw and drilled the mounting holes. Easy to bend around the swingarm. Fit perfectly and works fantastic. After 350 miles, there's not a mark on the Tivar, even though the chain drags across it regularly.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Postby Kcfirebolt » Tue Apr 14, 2015 9:11 am
Would it be possible to take a picture and post/email it to me?
charleswmillerjr at
gmail dot com
Kcfirebolt
Postby Kcfirebolt » Tue Apr 14, 2015 1:37 pm
I've ordered a foot long piece of Tivar from Ebay. Should be here in a few days. Thanks. Still would love to see a pic of your set up.
Kcfirebolt
Postby MZCountryRider » Thu Apr 16, 2015 8:52 am
A couple of photos when I was making the guide for the Elefant.
Made a cardboard pattern:
Covered the Tivar sheet with masking tape and transferred the pattern to it:
Cut out on the bandsaw, mounting holes drilled and installed:
Charlie
'73 Guzzi Eldorado
'76 Guzzi I-Convert
MZCountryRider
Postby Kcfirebolt » Thu Apr 16, 2015 11:28 am
Thank you for the images!
Kcfirebolt
Users browsing this forum: Google [Bot] and 64 guests
