chain roller size equivalent
Postby handsomejackuk » Tue May 26, 2020 5:06 pm
anyone replaced the two chain rollers towards the front of the sing arm the rubbers on mine are pretty worn, and would like to put some new ones on there are there any equivalents as fitted to other bikes or anyone know the diameter.?
Re: chain roller size equivalent
Postby DAVID THOMPSON » Tue May 26, 2020 9:57 pm
the most abused device in history skate board wheels ..
they make good frame sliders also
just put a very good bearing in them
Postby Puffs » Wed May 27, 2020 4:21 am
Many enduro/MX bikes have rollers like that.
Normally 2 sealed bearings in there. And they both die quickly, it is not a comfy life they have.
Postby handsomejackuk » Wed May 27, 2020 4:19 pm
DAVID THOMPSON wrote:the most abused device in history skate board wheels ..
done the skate board wheels for my axle sliders,
for reference they are 32mm diameter, 28mm width. i took mine off today, and mounted them in my lathe and turned them smooth job done saved myself a few quid they be ok for the moment.
Postby DAVID THOMPSON » Thu May 28, 2020 12:42 am
if i ever move i will build a box trailer and put the lathe in it and take it with me
you can use it to wind up a transformer to make a buzz box welder
and things are good
