john_pcb96 wrote:Hi having problems with my traveller, runs great for couple of miles then dies. Back to the mechanic, carbs and other bits sorted so its down to electrics, fires up great, ticks over, but on a run under power, misfires and dies, replaced coil, plug cap, lead and eventually 2nd hand cdi Rund much smother but gets really hot - gold exhaust - so stopped that one. Does anyone have a cdi that I could buy or borrow. does anyone know where they can be repaired or bought? Any help would be great - thanks
Tramcard wrote:this sounds like the probel i had years ago. It was probably a short in the wiring down around the neutral switch. Never found it as moving the wires to see what went where cured the problem and it has never reoccurred.
Last week iginition went a bit erratic as did the indicators. I had fitted a buzzer to the indicator circuit to indicate system was working and did not get left on. Getting older meant hearing reduced and I could not hear buzzer so replaced it with a LED light. This worked OK until the recent problem. checking through I realised the LED had shorted a bit and this caused the ignition problem, removing it solved problem. I am now back to having to try to remember to cancel indicators. However it does show that a small circuit fault can seem as if the ignition and the CDI unit might be at fault.
The first time around i changed the coil, stripped the carburetor, checked the tappets and was thinking it was the CDI until I fixed the problem without knowing what I had actually fixed.
Users browsing this forum: Bing [Bot] and 29 guests
