Baghira rear suspension bearing
Postby Uncle Nick » Sat Jun 07, 2025 10:47 am
Hi all, would anyone know the bearing number for MZ part number 901313100?
The spherical impact bearing 12mm x 26mm x 13/16mm, number 8 on the diagram.
I’ll try Grahams on Monday but suspect a bearing supplier will be cheaper.
Uncle Nick
Re: Baghira rear suspension bearing
Postby netguz » Sun Jun 08, 2025 7:57 am
Hi Uncle Nick.
Warning; Please double check all I say because I'm working from memory.
MZ part number 901313100 also fits the Skorpion and when mine failed I was incensed that, c2010, it would cost £58.
Bearing suppliers were almost as annoyed as I was but for a different reason. It was the 13mm measurement that made it a 'bastard' size which are frequently used in the motor industry and don't have a standard i.d. number.
Somehow or another I found out that a Yamaha Raptor used the same bearing and AllBalls made a kit that was something like £20 for two bearings and seals. I pounced.
The problem is that I can't remember which Raptor it was - sorry.
I've no experience with this firm https://www.dirtbikexpress.co.uk/products/all-balls-yamaha-rear-shock-bearing-kit-upper?variation=419730&gQT=2 but they have the AllBalls kit for the Raptors - 'praps they can advise.
Similarish https://www.teknikmotorsport.com/rear-shock-bearing-kit-soqi-26od-12id-13-15-wide but 15mm instead of 16.
Maybe https://quadbikeswales.co.uk/yamaha-yfm350-warrior-banshee-raptor-upper-rear-shock-bearing-bushing-kit.html can help.
Good luck.
netguz
Postby Uncle Nick » Mon Jun 30, 2025 7:57 am
Hi again and thanks for your reply and help.
I took out one of the remaining bearings and it had a number on - HK1812V so it’s four of them plus the spherical dollar bearing, which has a M12 bore, and 26mm OD, which I believe is a GEK12T.
Mine was totally rusted and seized, with no chance of finding a number but the GEK12T seems to fit ok.
Uncle Nick
Users browsing this forum: Bing [Bot] and 8 guests
