funky Choke on a 125 SM
Re: funky Choke on a 125 SM
Postby DAVID THOMPSON » Sat Feb 25, 2017 3:21 pm
seatbolt location
there is a bolt in bottom of seat right about over center of the rear tire
it is item number 4
in the attachment
http://www.grahamsmotorcycles.com/web/S ... M_SEAT.htm
Postby Rockybal1 » Mon Feb 27, 2017 3:21 am
Thanks for your help.
Many thanks
Rockybal1
Postby Rockybal1 » Mon Feb 27, 2017 3:25 am
Many thanks
Could you tell me if the mx 125 sm has a automatic choke I can't find it ?
Rockybal1
Postby DAVID THOMPSON » Mon Feb 27, 2017 8:31 am
its a twist unit on the left handle bar grab that handle bar with your hand
and your thumb can find it it is between the rubber grip and and the switches
Postby stephendacosta » Mon Feb 27, 2017 5:40 pm
There is a dzus fastener above the rear tire on the under side of the fender. turn it counter clock-wise(may stay with the fender or come out. also may have been replace with a bolt by previous owner). Once it is loose, pull the seat to the rearward to disengage from two tangs; one at front and one at rear of seat.
Stephen DaCosta
stephendacosta
Previous
