Fork spring dimensions
Postby baroquenride » Sat Nov 23, 2019 1:36 am
Anyone know the fork spring dimensions? I don't want to take my springs out to check as I'm still riding it lately and hoping someone knows the length and diameter.
baroquenride
Re: Fork spring dimensions
Postby DAVID THOMPSON » Sat Nov 23, 2019 7:05 am
is it the newer 4 stroke rt125
Postby baroquenride » Sat Nov 23, 2019 11:40 am
125SM
baroquenride
Postby Puffs » Sun Nov 24, 2019 6:28 am
Postby baroquenride » Mon Nov 25, 2019 5:25 pm
Changing preload does absolutely nothing for the spring rate which is what needs to change for me. I'm just hoping someone knows before I take one of the springs out myself. I'm hoping to cheat and reuse one of the several sets of springs I have stored.
I had some time to pull the spring out and it measured 32mm x 55cm long with a progressive section on one end about 2" long. Nope, I don't have a spring I can substitute.
baroquenride
Postby Puffs » Tue Nov 26, 2019 6:53 am
Postby baroquenride » Tue Nov 26, 2019 4:06 pm
I'm very familiar with all that, but might be helpful for someone else in the future.
baroquenride
Postby Puffs » Wed Nov 27, 2019 8:02 am
But of course you are. You asked, I just tried to help.
Out of interest: what problems do you have with the stock springs?
Postby baroquenride » Fri Nov 29, 2019 10:01 pm
--The spring rate. I'm 230lbs out of the shower. The stock springs are probably meant for a 150lb rider. I'd have to measure them against a scale and yard stick to calculate the rate, which I could have done the other day when I pulled one out. Perhaps next week I'll check.
baroquenride
Postby Puffs » Sat Nov 30, 2019 7:21 am
Thanks, I suspected something like that, or bottoming-out @ hard braking. You might find more suitable springs from another bike at a breaker?
Otherwise still: a bit of extra spacer to increase preload, + bit higher oil level.
Postby baroquenride » Sat Nov 30, 2019 9:12 am
Yes, I'm considering cutting off the progressive end of the springs to increase the rate and using a longer spacer to match the length and add preload, however that still wouldn't give me the correct rate for my weight and riding ability and my thought is, "what's the point?" I'd rather leave it stock in case I someday sell it. This is a fantastic bike for a smaller person and it may someday get sold to someone smaller and lighter person than me who would appreciate the stock springs.
baroquenride
Postby DAVID THOMPSON » Sat Nov 30, 2019 7:51 pm
i weighed 230 to 235 LB most of the time i have owned mine
and found it to be a delight to ride
Postby Puffs » Sun Dec 01, 2019 8:25 am
Not trying to say anything about your ancestors, of either of you, but I'd guess the bike was primarily designed for its home market, and Germans are not commonly regarded as 'petite'. But indeed, the bike was probably aimed at young guys, which tend to be lighter than Helmut Kohl (6'4", 300+lbs).
Anyway, on replacing the narrow spaced part by a longer spacer: yes, that will increase the spring rate (see formula above), BUT: you'll ruin 2 otherwise perfectly fine stock springs, and if you cut off a spring (angle grinder) without first properly shaping the end (oxyacetylene torch) it will bend on load & grind onto the stanchion. Yes, "what's the point?" springs to mind (pun intended).
I'd just add an ½" spacer (nylon ring) on top of the existing ones, raise the oil level a bit, and then just enjoy the bike the way it is.
You can't always get everything exactly as you want it. Which is good, for it leaves things to be desired!
