Wow... that sounds demotivating.
Sorry to hear of all the troubles you're having with this, don't quite understand why...
Blurredman wrote:Ever find out why ? Or has the whole MZ debarcle been put in the back of your mind and the MZ in the back of the garage?
dirtsurfer wrote:But it did give me a feeling of joy; like finding a destitute animal abandoned in the bush, taking it home, nursing back to reasonable health then setting it free again.
The sump plug magnet was broken, I noticed after my third stripdown but at that stage I concluded that if it was indeed interfering with something in the gearbox the foiling projection was broken off (the gearbox plug). Maybe I was wrong - I have another one to strip down now so I will pay special attention to the clearances around the gearbox drain plug and the moving components of the gear box. The other thing the new owner said was wrong is the star shaped index that sits on the end of the selector drum was around the wrong way. I'm pretty sure I checked that as it is a well documented issue.Puffs wrote:Yes it's a pity the MZ never worked out for you Max, and if ever you find out the cause please share it for the benefit of others. That oil plug is just a bolt (indeed some with a magnet), and unless it is excessively long, I don't quite see how that would cause these problems.
Users browsing this forum: Bing [Bot] and 29 guests
