TS125 - Rear Wheel Binding
Re: TS125 - Rear Wheel Binding
Postby Throwley » Thu Sep 08, 2022 3:45 am
Puffs wrote:Ta for that continued investigation & letting us know: pivot post not perpendicular in the brake plate...
But it raises the question: how is this possible? I would guess that in their production process they had a mould used for casting that plate, and a drilling process that should ensure it's all true. So something must have happened in the +/-40 years since. Is it the top one, which gets most of the force during braking? It the post bent?
It's the pivot drilling through the shoe which has not been drilled perpendicular. It's about a degree or so off. They look to be recent shoes, I guess quality control is not as high on the agenda as it should be for some of these aftermarket parts suppliers. It was probably caused by a lump of swarf holding the shoe off the datum point on the drilling jig, I reckon.
TS125 and ES150, but still with ES250 aspirations
Throwley
Postby Puffs » Thu Sep 08, 2022 6:52 am
Right, I misunderstood. With a column drill that could be rectified.
Previous
