Re: Not so common ETS 250
Posted: Mon Feb 07, 2022 1:00 am
Puffs wrote:Maybe - if you can. It might get a bit messy.
As an alternative, consider making a makeshift clamp from a 1cm/0.5'' thick piece of wood (say 3"/8cm wide, or more). First drill a hole in it with the size of the stanchion OD (~32mm). Then drill 2 holes for bolts, along the width of the wood, close to the big hole, and finally saw the piece of wood lengthwise. With the bolts in, you have a clamp that goes above the spring. You compress that spring first, to make sufficient space, and you use the clamp to keep the spring down. Then you can grasp the stanchion by it & manoeuvre it in place. Not necessarily quite like that, maybe a bit thinner & longer, just to show the idea.
Not tried, never worked on an ES/TS/ETS. I do not know what rubber pads there are inside that lamp holder, maybe they need guiding from above during the fitting. The clamp would only solve the problem of gripping the stanchion.
Beware of the damage this makeshift tool will cause, so that successful repairs will not be ensured...
Edit: the other approach could be to first fit the forks without those lamp holders, then support them at the bottom, take the top triple clamp off & fit those lamp holders, and finally re-fit the top triple clamp.
Hi all
I have been a bit tied up with returning to work ( ordered back to the office for 4 days the orderred to work from home again) and a coiple of weddings ; one in Adelaide and another in Hobart . Which has kept me out of the garage over these few weeks. The external springs hindered the use of a construction as you suggest. They're pretty strong and the wooden blocks would have to be much thicker to keep the spings compressed, then I run into the issue of the thickness of the wood simply replacing the the space previously occupied by the uncompressed springs.
Setting the cups , cones and balls in place in the steering head was difficult enough (for me) without the forks in place, I am reluctant to disassemble again the top clamp again but I may have to go that way.
I have made a visit to the same man who turned down the the stearing head top nut and asked if he could make a tool with a 27 X 2 external thread on one end and M12 internal thread ( to accommodate my slide hammer) on the other end. In the back of the MZ manuals there is technical drawings for these tools. So I took the drawing along to give the impression that I at least vaguely had an idea of what I was talking about. I also watched a number of thread cutting videos such as this https://youtu.be/Lb_BURLuI70 as homework
He is a lathe guy and devotes his waking hours to engineering fiddly stuff that I prefer to avoid if possible. I was pretty awestruck by the setup he has in his work shop. I'll see what he comes up with.
I am still waiting on fork gators to come from China
