hi guys.
i'm mohammad from iran and bought MZ ETZ 251
for per 17 litters gas into the tank how much oil need for mix?
and in summer use oil(car 40) or motorcycle oil for mix in gas tank ?
Blurredman wrote:Mohammed, the 251 should have an oil pump already attached? Is it missing/removed?
I would use just 2t oil if you can.
Guesi wrote:Hello
Mixture is 1:50 . 1 liter 2 stroke oil for 50 Liter fuel.
There was an importer of MZ motorcycles in Iran in the past years.
Maybe you can find him if you need parts.
I have a phone number, if you are interested I can give you that number.
But I don´t know if it is still up to date.
It is from 2011.
parrbd wrote:This bloke is an MZ enthusiast located in Iran. Maybe he can help. https://www.youtube.com/@hassanmz250/videos
breakwellmz wrote:If you mixed 1 litre of oil in into 14 litre of petrol that is far too much oil, if it runs it will run bad and smoke too much.
Blurredman wrote:breakwellmz wrote:If you mixed 1 litre of oil in into 14 litre of petrol that is far too much oil, if it runs it will run bad and smoke too much.
We're not entirely sure what oil is being used. To be sure, if using motor oil (and that might be all the OP can get) then a little more is usually accepted, but 1litre does seem a bit excessive- but I imagine our bikes would run on that fine. Actually, I used to double the quantity of oil I used to put in my tank on public ride out events just for fun.
Users browsing this forum: Bing [Bot] and 14 guests
