My 251 project that is now having a sleep.
Postby Blurredman » Tue Jan 30, 2018 3:57 am
Hi guys,
Just blowing my own trumpet in this post really..
In March 2016 I acquired a completely seized and almost unusable 1990 MZ ETZ 251 for £100 from a friend in the MZ facebook group, simply asking for offers. I only really wanted the bike for parts, namely the exhaust pipe (original) and the carburettor. It had on the clocks 29,900 miles on it.
It soon became apparent that It seemed it wouldn't need a lot to get it on the road, and especially as I don't have a garage where I live, I thought I would put it on the road and use it as my commuter.
So first thing first was getting that seized piston out and after a lot of banging with the hammer, I got a very poorly piston out of an equally poorly barrel. It seems that the bike had been off the road for 13 years before I got it, and water had got into the barrel. Luckily the water did not leak down into the crankcase, as the piston was stopped in a position where by all the ports were blocked by the piston. But it was very rusty in the upper of the barrel and the piston was totally unusable, especially after my banging it out.
I put on a spare barrel and piston that I had, which was quite worn, but I said to myself that it was only going to be a temporary measure.
Then I couldn't set the points, namely because the points didn't open at the correct sparking angle, unless the gap was set at around 3mm. I continued to use the bike for a little while however, and I used to break down about twice a day (from and to work). I would notice that the points would stick open when the bike stalled and associated as that being the reason why it stalled out. After a few unsuccessful attempts at buying old and reproduction electronic ignitions I purchased a polish kit that has worked perfectly ever since installation. I did however find that it was still stalling, and after a while I got it down to the coil being the cause. I took my other MZ's coil and all seemed well! I finally had the machine at a stable and reliable state. And other than a speciality in blowing bulbs for the first few weeks it was great. I had decided that my goal with this bike was to spend as little as I could, using what I already had to get it on the road, like a round (twin bulb) rear light unit and an indicator from a 250, and the like.
I must mention that at this time my '87 ETZ 250 had thrown a conrod bearing and I was therefore using this 251 constantly. I had reservations regarding the quite poor performance, and the fact I had to replace the clutch cover as he kickstart stop had been smashed and engaging the rachet. I did notice that the clutch had been apart in it's past, and the end of the crank was quite mashed. The clutch worked however so although I knew it might need to be looked at in the future, I ignored it for the time.
Soon after I took the bike to Turkey on a round trip of 5,000 miles, where I made very little preparations for the bike. I already had a rack, but was broken in a couple of places, which was welded up, as well as the tank mounting flange and seat base also being welded. Where it did extremely well! It was happy at a constant 70mph, and I had no issues at all other than mis-firing when it was raining. Not the type of thing you want when you're in Greece, needing to get to accomodation in Bulgaria, but in total it only rained three times so it wasn't a big issue. I was surprised that I didn't even get a puncture! And I often travelled over 600 miles a day. The spares I took with me didn't get touched, and the spares included voltage regulator, points (incase the electronic ignition failed), wires, rectifier, I didn't even get a puncture, despite my foresight to bring both a 16 inch and 18 inch tube with me as well as repair patches. I went through a gallon and a half of the cheapest two stroke oil. I was using 30:1 ratio pre-mix. The clutch cable snapped just 40 miles from home, (it had been stretching for some time and the final adjustment I made snapped it). :lol:
I did crash once (dog ran accross the road), and despite the fact I came off at 30mph, the only damage was an indicator lens and a bent footrest (It was raining just previously so is simply slid quite nicely down the road), which I resolved when I got home a few days later. I.e bending footpeg back (and grinding the burred edge away) and fitting replacement lens.
[img width="800" height="600"]http://blurredmanswebsite.ddns.net/pictures/bikes/mz251/leftbul.jpg[/img]
Anyway, the time has come whereby the machine is going to surpass the (according to clocks) 40,000 mile mark and it was a self goal that I set. I have a number of things I wish to do with it, because at the minute it is quite a chore to ride. I have made a list of what is wrong, and what I need to do to it:
1) I have the original barrel re-bored and a new piston to go onto it.
2) I need to rebuild the clutch - and therefore flatten the end of the crank somehow to be able to pull it off..
3) The front wheel is twisted and pulsing, the handlebars wobble considerably.
4) the rear drum is oval,
5) The engine in itself seems quite fruitless and does not deliver power in a pleasurable way. This could be because it needs a piston that doesn't slap (I will measure the gap when the engine is apart), but this could also be because of the engine being generally quite worn- it has had a very hard life it seems, with the new piston being a 4th oversize!
6) Electrical connections need to be renewed as I am now fighting a constant battle with charging/electrical issues from the generator.
7) Gearbox very clunky!!
8) It does not rev out fully.. It can achieve 75mph, but even in lower gears at lower speeds the engine revs out at around 5k and isn't generally a happily revving bike.
So, 10,000 miles in 1.5 years, and the bike needs considerable work being done on it, and the 'temporary' barrel and piston replaced again with original. :lol: :roll:
In general though, I am very pleased with the motorcycle and cannot complain. But I have finished rebuilding my '87 250 (bearings, crank etc- and a 1st oversize 300cc piston) and I cannot wait to ride it as it is a MUCH MORE pleasurable motorcycle to use, regarding power delivery, Gear selection is very pleasurable, suspension is nice, brakes are not warped etc. I just need to get some run in miles done on it :lol:
1987 MZ ETZ300 - 40,000 miles
Re: My 251 project that is now having a sleep.
Postby Puffs » Fri Feb 02, 2018 7:06 am
Hmm... Round trip to Turkey.. that does sound appealing!
And I see yours has the same brand of seat cover as I used.
On your 3) & 4), rebuilding the wheels may help. Just a little teaser from my side:
I hear you're using 30:1 ratio pre-mix, any reason you're not using the oil pump? That said, mine lost its small-end conrod bearing after about 25k miles.
Postby Blurredman » Fri Feb 02, 2018 9:29 am
Main reason for pre-mixing was that I have always done it really, and unlike a lot of people, I don't find it all that much of an annoyance to put 2t in with the tank when I re-fuel.
The bike in question has had a hard life, and it's not that I don't dis-trust the pump, but it takes out the equasion of it going wrong, esspecially on such a large trip whereby if I cannot fix it on the side of the road, then I would have to leave the bike where it fell and find another way home.
The fact that I was using the cheapest two stroke oil I could buy but was often at a constant cruising speeed of 55-70mph, equates to the fact that synthetic oil is a waste of money for me, and for most.
Postby Puffs » Fri Feb 02, 2018 12:33 pm
When they were still racing these bikes I believe they also pre-mixed, obviously to allow better control on the ratio. I believe the standard pump does something like 50:1, which would probably not be rich enough on heavy load. In my MX days I used 35:1 Castrol TTS in water-cooled KTM's & YZ's (Yamaha prescribed 24:1 Yamalube).
As said, I haven't used the MZ for over 12 years, on nice days I do some touring here with a '76 Jawa 634. It's the only model that doesn't have an oil pump, and I pre-mix 32:1 with a very cheap modern semi-synthetic. That bike has cast-iron barrels, which run at a higher temperature (which helps condensation of oil from the mix, or rather evaporation of the petrol component). I think the advantage of a synthetic or semi-synthetic oil is that it doesn't burn so easily, hence tends to stay more liquid. So rather than carbon inside your exhaust, which plugs it over time (which makes it run like a potato, as they say here - could that be your problem 5)?), you get a foul sticky black goo dripping from your exhaust. And you get very little carbon inside the cylinder head & below the piston crown.
Postby Jay Bee » Sun Feb 04, 2018 6:14 pm
I'm really not sure whether I should add to this thread, or begin a fresh one, but here goes.....
When or maybe that should be if I have finally resurrected my ETZ 125 long-term project, is there any valid reason why I should not use fully-synthetic oil,
(namely Castrol Power 1 Racing 2T)?
I am currently using this oil in a Honda 2-stroke scooter that I use for local errands - following the maker's recommendation for fully-synthetic, (which it had been run on since new).
When I acquired this bike it had stood fully 16 years unused - and it's the only 2-stroke bike I've ever owned that hasn't developed bearing problems within 500 miles or so of re-use following long-term storage .I should add that with a top speed of just 30mph, this bike gets ridden everywhere absolutely WFO ....engine runs as sweet as ever, with no noises and once fully warmed-up, with no visible smoke, either.
My ETZ, a Luxus variant with autolube, chewed its small end bearing - when I drained the oil tank, all that came out was some very thin, colourless liquid - water?/diesel? whatever, it can't have been much use as lubricant !
Apologies if I've stirred up a "what oil should I use ?" old chestnut - I know that these can be the bane of web forums such as this. :oops:
Jay Bee
Postby Blurredman » Mon Feb 05, 2018 4:29 am
The question of 'what oil?' is an age old one.
I've never used synthetic, or even semi- synthetic. It is my oppinion that these bikes run perfectly well on standard mineral, and that using synthetic doesn't necessarily do any benefit other than give the user peace of mind.
I am unsure what kind of water ingress gets into the two stroke oil tank. But unless the breather tube is routed and the end is pointed down, i'm sure water spray and rain might get into it.
But as I mentioned in my original post, I had been using (as I always do) cheap, bulk mineral two stroke oil for 10k miles and I use this oil for my other two strokes, which are in my signature. I have yet to take the engine apart to investigate various problems with it, but seeing as the piston is quite worn anyway, the result is accademic. :lol:
Postby Puffs » Mon Feb 05, 2018 9:41 am
Jay Bee wrote:is there any valid reason why I should not use fully-synthetic oil
Money?
Of course these bikes also run well on conventional mineral oil. Doubtlessly that was used for the first 4 (?) decades of 2-stroke history, and in their standard tuning these engines have quite a low power output. And are well constructed. So I don't see a problem, load & lubrication-wise. But imho you do get more carbon, so a bit more maintenance may be required. A fully synthetic will have a narrower range of components, giving better stability at high temperature (and possibly a higher film strength), but if you need that in a relatively modern MZ I do not know. But if you buy synthetic, you will pay for it. It's a choice.
I cannot remember why the small end failed in my 251; it was some 18 years ago. But I don't think it was due to the wrong oil. At the time I used a modern fully synthetic 2-stroke oil.
The oil I currently use (so far only for the Jawa, but I'll also use it for the MZ) is what I managed to buy a batch of 20 litres of, cheaply.
Jay Bee wrote:bearing problems within 500 miles or so of re-use following long-term storage
Yes, that happens. If it does, I think it is due to corrosion on the bearings, due to humidity.
Users browsing this forum: No registered users and 169 guests
