How can I make an 02' Moskito 125R FASTer!!!!
Moskito, Moskito SX, Moskito RX, Moskito 125R, Charly scooters.
Moderator: DAVID THOMPSON
Postby CLUTCH NUT » Thu Nov 10, 2005 12:10 pm
Can it be derestricted? how about a pipe and jetting? and a place to purchase? Thanks !!!!!
Stay-C
CLUTCH NUT
speed mods
Postby DAVID THOMPSON » Sat Nov 19, 2005 10:26 pm
the rear tire size is a ratio ie 120/70 against 120/90 equals
a gain in top speed but not enough to try unless you need a new tire
because it would only be 1 or 2 mph if that
what is the stock tire size now
Postby antonio » Thu Jun 22, 2006 7:22 am
Does Moskito has the engine restricted?? I didnt encountered any speed restriction with my Moskito...
btw, back to the question....Firstly of course the exhaust pipe, it is the most effective mods to go for beside changing bigger carbs or roller...
After a good exhaust system is available, fuel jetting should be taken into considerate....change up to 15-20% in size comparable to the stock...
MZ Moskito 2005
125cc - 150cc Tokahi Racing Block
Racing Cam Stage 2 (Taiwan) Lift 11.5mm
Mikuni VM34
Malossi Air Filter
SpiltFire Spark Plug Cable
NGK Platinum
antonio
Postby daniel john » Thu Jun 22, 2006 1:31 pm
hello antonio...well...modded exhaust will produce louder sound than the original one...is there any way to make the sound to be more relax? cos i dont want my neighbour to hate me...hahaha...i saw many of those loud pipe scooters on the road...n i dun wan my exhaust to be loud like that...hahaha...
daniel john
Postby antonio » Thu Jun 22, 2006 8:15 pm
You can custom made (if ur in KL) and it doesnt have to be loud...just a simple of removing 'some' restriction in the exhaust will gain you much better throttle acceleration and also some top speed...:)
MZ Moskito 2005
Mikuni VM34
Malossi Air Filter
NGK Platinum
antonio
Postby daniel john » Wed Dec 06, 2006 3:11 am
i change the roller to 9g and contra spring extra 10kg recently...more response on throttle but no speed gain...for me my scooter speed is ok...
daniel john
swing
Postby DAVID THOMPSON » Wed Dec 06, 2006 10:18 am
becareful with the belt transmission weights if set wrong they can make belts
be used faster.. but it is better for getting up to road speed going onto the freeway
:-D
a 250 cc or 500cc scooter is the answer unless your country has a size limit on motors i can see it now the best scooter of all time a bmw r1200 motor in a home made scooter :-D
Postby daniel john » Mon Dec 11, 2006 1:58 am
yah...but i change my drivebelt religiously...hahaha...im not doing anything to my engine...just a roller n contra spring...thats enuff for me to enjoy the scooter...
daniel john
Return to Scooters
