MZ 125 clutch
MZ 125 clutch
Postby Ezzelino!! » Fri Jul 31, 2009 4:38 am
Hey!
lately my bike has been reving freely a lot whilst i insert gear. In a fe words I think I wore out my clutch. What do I ahve to buy exactly. Just a friction plate or the whole set (EDIT DEAD LINK HERE and add //try ebc KIT CK4436 dave)
Please note that I have not opened up my bike yet but I am sure that it is a clutch problem. I just do not know what buy to replace the worn parts
Bests
Rob
Ezzelino!!
Re: MZ 125 clutch
Postby DAVID THOMPSON » Fri Jul 31, 2009 11:17 am
there is an adjustment on the cable and an adjustment on the basket in side
green arrow = adjustment
black arrow = clutch springs not in picture
RED ARROW oil pressure spring and ball bearing do not loose
make sure its in there
make sure you use a good side cover gasket as its thickness effects oil pressurw spring
i remove battery and lay bike on its side ----saves hunting for oil ball and spring.....
i would replace the whole set
blue = the location of the famous freewheel drum
the copper thing in front is a 2 way slip clutch it gets galled and does not slip when it should --breaking the freewheel
book says not field adjustable but i did after breaking 3 freewheel drums
details on adjustment on request
click on picture for full size view
right side mz125
125right side514.JPG (164.26 KiB) Viewed 25825 times
Re: MZ 125 clutch
Postby Ezzelino!! » Sun Aug 02, 2009 3:05 am
So Dave I have to buy the whole set listed in the link ?
good side cover gasket.. an original one would do ?
Ezzelino!!
Re: MZ 125 clutch
Postby DAVID THOMPSON » Sun Aug 02, 2009 10:35 am
i try to keep a couple side cover gaskets in stock as waiting 7 to 14 days to get one stinks
you may salvage the old gasket -- maybe not and oil leaks are no fun
and how many miles on bike
i would replace the whole kit springs and all
i have 18 500 miles on my clutch it still works ok but all adjustment play is gone
so it will be a winter project here
and i got lucky i bought a spare engine and it had an extra complete clutch basket with it
so i got a low cost clutch replacement .its used but still almost new specification
also there are 2 rods and a ball bearing in the center of the main shaft when you have clutch apart do not
let them fall out they will stay if bike is laying on left side or leaned that way
do look at parts book before taking it apart
very simple bike to work on ---- most of my problems have been the electrical stuff
a note on electrical
some of the new bike i have been working on the electrical stinks
the designers are doing such a poor job and the parts and wires are of poor quality
they are actually making JOE LUCAS the original prince of darkness look like he knew what he was doing.....
Re: MZ 125 clutch
Postby Will Evans » Sat Apr 19, 2014 7:06 pm
Hi Dave
Do you happen to know the thickness of the clutch cover gasket? I have struggled to find a Quality replacement in the UK and happy to make my own but after seeing a few other posts it is clear the thickness is important. All roads lead to you on this subject and I was hoping you could help?
Kind Regards
Will
Will Evans
Re: MZ 125 clutch
Postby DAVID THOMPSON » Sat Apr 19, 2014 8:14 pm
http://www.grahamsmotorcycles.com/2010% ... filter.htm
above link is dead follow it and go to there main page and look for parts book
https://grahamsmotorcycles.com/MZ_Parts ... filter.htm
if above link goes dead look for 125 oil filter page
item 17 depends on your serial number
and 14 15 and16 is the oil pressure parts
the paper gasket you can make
it just needs to be the correct thickness so it does not effect the oil pressure
i have a new one in the basement but nothing to measure its thickness with till later
as lights are off in the basement working on the electric supply and hunting for some thing with a flashlight
is a bit of a pain// tomorrow maybe
these bikes are nice and well worth fixing if you can
as no one is making any thing that compares ..
Re: MZ 125 clutch
Postby Will Evans » Tue Apr 22, 2014 3:16 am
I agree I have inherited mine off of my srep son who came off (nothing serious) and quickly lost intrest in bikes.
Shes a bit beat up and I finally got her started on the button once I changed the sprag clutch (thank you for all your help on that one btw :) ) and the standard carb clean where it was stood for too long.
Ive only managed to test ride it around the block due to the dodgy gasket and I keep missing sunny days so you can imagine the frustration ;) but the bike seems solid and well balanced looking forward to the summer commute!
I have a few bits outstanding before she is truely road worthy though such as service the forks indicator change etc... Then ill be looking to sort out the plastics as many of then are cracked and scuffed presumably the bike has been through a few teenagers before my step son lol
Will Evans
Re: MZ 125 clutch
Postby DAVID THOMPSON » Tue Apr 22, 2014 8:24 am
numbers for cork plates
ebc ck4436 fits kawasaki from the 1970's or 80's
lucas MCC201-6
the hard starting goes away if you run fuel with no ethanol
mine started this spring ..with very little fuss after a winter on the front sidewalk
and trust me it was not a nice winter...
also lean it over to the right a bit and drain the float bowl every once in a while
little screw on the left side bottom is the drain
as i have said before these things are just a large MOPED so do not flog them for more than they can give....
Dave
Re: MZ 125 clutch
Postby New2MZ » Tue Mar 09, 2021 12:20 pm
Hi, old thread but new bike to me. Any instructions for clutch adjustment at the basket? At the moment it seems liked the engine is being dragged down by the clutch and stalling when the clutch is pulled in, no more adjustment available at the lever. Was there any info on the thickness of gasket?
New2MZ
Re: MZ 125 clutch
Postby DAVID THOMPSON » Tue Mar 09, 2021 1:33 pm
about as thick as 20lb printer paper but gasket paper
and a paper punch is best for making the holes
use the outer case to make a trace of size
Dave
in my area the gasket paper is getting hard to find
Return to 125 cc
