Skorpion substitute part database- please add!
Re: Skorpion substitute part database- please add!
Postby arry_b » Sat Feb 15, 2014 2:27 pm
TRX 850. It's the best upgrade you can make to an Skorpion, especially when fitted with a good quality bulb (Philips +60% for me).
I can see where I'm going on low beam now on my Traveller, which is rather a novelty after years of squinting into the gloom.
arry_b
Postby Kcfirebolt » Fri Feb 28, 2014 3:52 pm
Anybody have a lead on replacement wheel bearings?
Thanks!
Kcfirebolt
Postby arry_b » Fri Feb 28, 2014 4:24 pm
They're just standard bearings, not MZ specific.
Take a look at:
http://www.grahamsmotorcycles.com/2010% ... _Wheel.htm
and
Or pop your wheels off and read the part numbers of the ones you've got in there.
arry_b
Postby Kcfirebolt » Fri Feb 28, 2014 4:52 pm
Thank you. We've pulled the rear wheel bearings and discovered the following engraved on the side.
6203-2R5(S?)1
Graham's confirms the first four digits. Are the last four important? Does it need to be an exact match or will any 6203 bearings work? Any one know of a good resource for these bearings here in the USA? Thanks.
Kcfirebolt
Postby Kcfirebolt » Fri Feb 28, 2014 5:11 pm
Just talked to Kevin at this place: http://www.thebigbearingstore.com/index.html
Very knowledgeable. Front and rear bearings are very common, and they have them on hand.
For the record:
Front Wheel: 6004-1RS C3 (I learned that RS stands for rubber seals. Didn't know that before)
Rear Wheel: 6203-2RS1
Kcfirebolt
Postby Nobog » Wed Mar 05, 2014 7:20 am
All, I made a quick summary of the above info, please let me know if there are any mistakes or additions (oil filter?). The image is a .jpg but if I can figure out how to load a .pdf or embed an Excel file I will do that. Jim
Nobog
Postby Srinath » Wed Mar 05, 2014 5:05 pm
Kcfirebolt wrote:Just talked to Kevin at this place: http://www.thebigbearingstore.com/index.html
For the record:
I've damaged the rubber seals seating a wheel bearing. You're better off getting 2SS bearings (2 steel seals) those buggers are harder to damage seals on.
I have made better tools than the crap you buy off the shelf, so I wont damage nothing now, but its worth noting anyway.
Cool.
Srinath.
Srinath
Postby tigcraft » Thu Mar 06, 2014 3:14 pm
Nobog wrote:All, I made a quick summary of the above info, please let me know if there are any mistakes or additions (oil filter?). The image is a .jpg but if I can figure out how to load a .pdf or embed an Excel file I will do that. Jim
That's a nice graph. Can't wait to read a clearer version. Eric
tigcraft
Postby FALAKAR » Tue May 27, 2014 3:11 pm
I used the front brake light switch off of a 2002 suzuki katana 600. I suppose a lot of bikes share that brake switch as well but i thought id add it to the list.
FALAKAR
Postby Old Dog » Wed Aug 27, 2014 4:57 am
Front caliper off a Cagiva mito plug and play
All the best
Old Dog
Old Dog
Postby Srinath » Wed Aug 27, 2014 11:22 am
An 89-02 US GS500 - Naked headlight also fits - and is far cheaper/easier to source.
Cool.
Srinath.
Srinath
Postby zippy49 » Thu Sep 11, 2014 2:19 pm
That list would be a lot more useful if it was more specific. There is no model of Buell that ever used the same turn signals as my '98 Traveller; it turns out that they are the same as on my 1995 Triumph Trophy. P/N T2700925. only $45 each! :shock:
Tom in SoCal
zippy49
Postby DAVID THOMPSON » Thu Sep 11, 2014 5:24 pm
ktm 99 duke will work 5841402500030 not the same but look good on my 98 traveller
thats a rear right number but will help find it
parts page
http://www.ktmpartspro.com/oempartfinde ... 2f09190049
Postby vicar » Thu Sep 11, 2014 6:14 pm
The TRX 850 headlamp holds a single bulb and was never imported to the US but the FZR400RR has a twin projecter style headlamp that fits the TRX perfectly so it will fit the MZ, but be warned the std TRX headlamp shite I have had to fit a 90/130 watt bulb in mine to get a decent light
vicar
Postby zippy49 » Wed Nov 19, 2014 10:54 am
Anyone know of a substitute part for the Traveller's rear view mirrors? Or at least something that would fit?
Tom in SoCal
zippy49
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
