Scorpian Sport - First impressions....
Re: Scorpian Sport - First impressions....
Postby Dave-the-rave » Sun Apr 13, 2014 6:25 pm
Found these pics of a Traveller but it looks like a Tour.Seems they have the same yolk as the Sport. Clip ons look like they fit on the fork uppers in the same way but they are higher, similar to a NTV650...
His - 1995 Yamaha XV750, 21 000 miles.
Hers - 1994 MZ Scorpion Sport - 40 000 miles.
Dave-the-rave
Postby edfmaniac » Sun Apr 13, 2014 7:11 pm
Here's another good shot of the stock Traveller set up. I found it to be more than touring friendly.
Postby DAVID THOMPSON » Sun Apr 13, 2014 7:47 pm
thanks mine are similar but still to wide
and i used the bars from a saxon tour but not too happy with how strong the whole thing is
pic of what i did when i find the camera
i do not want to drill my stock triple clamp for risers unless have too
but not happy with iT as i have said many times i am not a fan of mods
but it kills my back the way it is....on a long trip i can get there quicker on the rt125
as the traveller just beats the crap out of me
Postby Srinath » Mon Apr 14, 2014 8:30 am
I have found the MZ replica and tour front suspension to be pretty stiff ... it beats up my wrists.
By contrast the Katana FE I have on my GS almost is too soft to even be on a bike that a 100 lb lighter than the intended kat 6.
Maybe putting that FE on a MZ is the answer ... the legs are the same dia ... so they should slide in.
Spacing I think is 1/4" wider on the MZ. Or is that closer to 1/8" Either way ... its close enough a few hours of machining can get you fitted up.
Cool.
Srinath.
Srinath
Postby Srinath » Mon Apr 14, 2014 8:36 am
MZ is 6", 89-96 katana is 5 and 3/4". The 97 and later katana is 6" I think. I dont have that sitting around now to measure it.
Cool.
Srinath.
Srinath
Postby zippy49 » Tue Apr 15, 2014 10:30 am
My '98 Traveller came with those Italian adjustable handlebars, and they seem to be plenty high enough for me. It also came with a full fairing and the Hepco & Becker bags.
Protip: You can remove the bolts that thread into the fuel tank quite easily if you hold the washer underneath from turning with a pair of pliers....that also keeps the insert from turning.
Tom in SoCal
zippy49
Clutch perch and cable part numbers
Postby poppanitrous » Tue May 06, 2014 4:35 pm
Aftermarket for MZ clutch perch/lever
poppanitrous
Postby poppanitrous » Tue May 06, 2014 4:36 pm
Besides ordering factory MZ replacements,ive tried a few different levers and had a cable made but it doesnt feel smooth,almost has a gritty feel through the stroke of the clutch pull.
I just read the NINJA EX500 cable will work,but im wondering what part# and what clutch perch and lever can i use from a YAMAHA ir KAWASAKI since that is the only dealer in my area here in the USA (FLORIDA).
I would like an admustable like my motocross bikes but i would be happ with anything smoother than what i have now.
Any ideas and PARTS#s for yamaha/KAWI, CLUTCH CABLE and clutch perch/lever combination thats works on MZ sport clip-ons?
Please P.M. Me with part#s you have used with success.
Thank you
poppanitrous
Previous
