MZ Spring.pdf
- Gear Selector Centreing Spring
- (102.7 KiB) Downloaded 663 times
Hi MJ,
Graham's confirm they have these in stock for a very reasonable 6 - 7 pounds. A huge saving on the $350 my local spring manufacturer wanted.
Here's the part you need;
33 3547306000 Rückholfeder für
Schaltwelle
return spring for shifter.
I found the broken piece in the sump. Tried retrieving through the sump plug hole with a magnet but missed it. Ended up removing the sump (Radiators and exhaust need to come off) which revealed absolutely no metallic material or sludge at all. Nice to know.
To get at the mechanism you need to remove the clutch. I made a special tool from a socket and used a rattle gun to remove the clutch nut/collar.
