Suggested trail tech model speedometer kit for 01 Baghira
Postby FasterByFate92 » Fri Dec 09, 2016 6:34 pm
Hello fellow mz riders, I know I may be on the wrong page for this, but if someone knows which trail tech digital speedometer kit works best for the 01 baghira I would appreciate the input, all I can find are kits for more popular bikes like Honda or ktm, I was thinking maybe the kit for the raptor 660 might be compatible, but I came here to get some further input. Again, sorry if I'm in the wrong place for this question.
FasterByFate92
Re: Suggested trail tech model speedometer kit for 01 Baghir
Postby rodge70 » Sat Dec 10, 2016 5:29 am
hi,any trailtech will do as mounting it needs a bit of creativity,think i did buy the raptor one though, and you will need the rpm resistor wire to smooth out the rev range which i think comes with the raptor specific one.
rodge70
Postby FasterByFate92 » Sun Feb 19, 2017 6:16 pm
I appreciate the reply, sorry for the late reply, bought the kit for a crf and have ran into some difficulties installing it, blinkers will not work with headlight plugged in, bike will not start without jumping neutral switch. I imagine fans will not kick in seeing as how the water temp sensing circuit also goes through the factory Speedo.
Any input from anyone who can help would be appreciated.
FasterByFate92
Postby DAVID THOMPSON » Sun Feb 19, 2017 10:06 pm
something is not plugged in right
there are diodes in the mz electrical system they can cause fits
attached file may help
look here
viewtopic.php?f=3&t=8464&p=44419&hilit=tony+idle#p44419
file is part of this post
click on it to make it bigger
and save the whole post an put a copy in your shop manual
the 660 bikes have an electric system you can learn to hate
lot of this also is relavent to the 125 bikes as well
:smt006
print below attachments for your shop manual i email this info out more than any other files
print them soon when you really need them your printer will be broken or out of paper and ink :smt023
Postby FasterByFate92 » Mon Feb 20, 2017 8:33 am
Thanks man, I will check that out when I get off work, I Will let you know how it goes.
FasterByFate92
Postby rodge70 » Mon Feb 20, 2017 3:37 pm
i fitted temp sensor on left hand side of cylinder head,cut into water hose,near fan switch i think.new speedo should have no effect on neutral switch,headlight, indicators etc whatsoever,seem to recall using oe wire for temp warning light to power seperate led to show when fan runs,bike was only a few weeks old from new at the time,to make sure all was good and when happy removed led and insulated wire as not used anymore.
if i get time will post a pic or two
rodge70
Postby FasterByFate92 » Tue Feb 28, 2017 8:21 pm
Alright, so I got this thing working it seems, turned out to be that my neutral safety sensor had decided to go out randomly. Replaced it and now works fine, I'm at the stage where I need to set up all the information for the Speedo to work.
Now I need to know :
High temp warning point
Over temp danger point.
Rpm shift points (this is a completely stock 2001 mz baghira)
Over shift indicator warning points.
If y'all could help me out this last time, I will post some naughty pics of my bike for you haha. You won't be disappointed, she's beautiful.
FasterByFate92
Postby FasterByFate92 » Fri Mar 03, 2017 12:01 pm
Bump
FasterByFate92
Postby MSW » Tue Apr 11, 2017 4:56 pm
Those are tough to answer definitively. I don't think I've ever seen any recommended shift points for a Baggie or Mastiff in any publication, whether from MZ or otherwise. You might have to just do some experimenting and come up with your own.
As for the over shift point, the manual says that the rev limiter is at 7,000 rpm, so you can use that as a guide.
On the coolant temps, I believe that the fan switch (at least on my 2005 Baggie) causes the fans to kick on between 186-201 degrees F, so you might use that as a guide as well, at least for the high temp warning point. Who knows what the danger point would be.
Not a lot of help, but I don't think there's much out there.
MSW
2005 Black Panther
MSW
Postby rodge70 » Sat Apr 15, 2017 3:37 pm
search my profile/posts and you will find vapor settings topic,settings work fine for me though overtemp reading i think is just below fan switch on point.fan comes on then temp starts to drop.
rodge70
