Skorpion substitute part database- please add!
Re: Skorpion substitute part database- please add!
Postby LA_Skorpion » Sun Sep 02, 2018 2:49 pm
Rear turn signals on my 1995 Sport are sold as "Baja Designs" part #60-4190. They are a very close match to OEM and are made in Italy
LA_Skorpion
Postby KarlB » Sat Jan 26, 2019 7:42 pm
So just rebuilt a 98 Skorpion Tour I can add these to the list of parts etc from other bikes that do fit.
Brake lever Honda NX125 (Italy)
Clutch lever MZ RT125
Front foot rests Triumph Trophy/Sprint/Tiger 1050
Replacement clock - from Amazon - Clock Insert 37mm Silver Bezel fits 34mm hole, Arabic Numerals, White Dial, Quartz Watch Insert
Front indicators Triumph Trident 900 1995-1998
Rev counter glass 100mm/4 inch Smiths Instruments
Rev counter bezel Porsche 356 or similar 100mm instrument bezel
Paint (Green) Volkswagen Perlcolor Gruen C6V/LC6V (ebay)
KarlB
Postby dellboy77 » Fri Mar 15, 2019 3:10 pm
1996 Ducati Monster 600 Rear Brake Master Cylinder - fits skropion
time is not important its the importance of time
dellboy77
Postby oldbiker1 » Mon May 13, 2019 2:18 am
please add..
KTM 65SX radiator cap will fit the Traveller radiator. Ive given it a great workout in cold weather and wet stuff, 1202kms in 3 days.
oldbiker1
Postby lavrentyuk » Tue Jul 23, 2019 2:45 pm
Skorpion rear master cylinder.
To confirm what Dellboy77 wrote the Brembo Ducati spare fits as a straight replacement and under Part No 62540151A Pompa PS11C Nera M651.
Thanks Dellboy77 :-)
Richard Marshall
Wales, U.K.
lavrentyuk
Postby ralf » Tue Jul 30, 2019 12:51 pm
Front indicators are also found on Triumph Trident 1995 - 1998
ralf
Postby turbodave » Fri Oct 18, 2019 6:07 pm
Anyone found a replacement tail light lens for a 2000 Sport Replica?
Dave
turbodave
Postby droy » Fri Oct 25, 2019 10:07 pm
Same as the Sport and Sport Cup but no direct replacement that I've seen is 25 years of ownership. I just picked up a NOS one off eBay for $40 and a rarely see any used for sale. Did the plastic posts (fake Crome) at the screw points snap off? Common problem if it did.
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Postby tigcraft » Sun Nov 03, 2019 3:06 pm
droy wrote:Same as the Sport and Sport Cup but no direct replacement that I've seen is 25 years of ownership. I just picked up a NOS one off eBay for $40 and a rarely see any used for sale. Did the plastic posts (fake Crome) at the screw points snap off? Common problem if it did.
I saw the one you bought and nearly bought it myself as it was for sale for ages. I need one as mines been cracked for several years but managed to live with it as it’s been repaired although a replacement is always better but I’m tight!!
tigcraft
Postby turbodave » Wed Nov 20, 2019 9:42 pm
Droy:
Thanks for your responce. The post in the lens itself have broken.
Dave
turbodave
Postby ironhorse99 » Sat Dec 14, 2019 11:38 pm
when my rear shock failed on my 01 traveller. I bought a Hagon shock. Way more robust in every way & adjustable too. Model HA M67080. Cost U.S. $394.00 (2007 price)
ironhorse99
Postby Zavodnik » Wed Aug 16, 2023 5:06 pm
Rear Brake Light Switch: Moto Guzzi GU14657050
Brake Light Switch Rubber boot for the above switch: Triumph T2500254
Zavodnik
Re: REAR BRAKE BANJO SWITCH
Postby jimc » Sun May 26, 2024 3:56 pm
The banjo switch for the rear brake light decided to cease function. Lots of el cheapo ones available, but I went for the Spiegler in hopes of better quality plus it comes with the 2 crush washers and has a perfect boot. Spiegler Performance parts P/N 20-01011-52. This is an M10x1.0 thread. This does come with 6 inch lead that requires a connector change. bought from Sportbiketrackgear.com.
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Postby dickl » Thu Sep 05, 2024 1:00 pm
Finally found a rear lamp for my Traveller on "bay of fleas" sold by autostore213 and described as "Universal M/C rear brake stop LED tail light licence number plate lamp UK" Less than £12!!
dickl
Postby AndyDent » Fri Feb 21, 2025 3:04 am
Ecstatic to say there's a new supplier of replacement Skorpion Sport screens!
Just fitted my newl-made replacement. They made a mould up from the pieces of my original.
https://www.eaglescreens.com.au/?productcats=mz-muz
Now just need to find a fairing shop to do a little crack repair & repaint, here in Perth.
from side so can see curve
Screen from front
Screen in place
AndyDent
