jpmsteadi wrote:Found one missing oring on the throttle shaft, a washer an o-ring flipped on the mixture screw
Puffs wrote:jpmsteadi wrote:Found one missing oring on the throttle shaft, a washer an o-ring flipped on the mixture screw
That absent 'O'-ring will cause 'false' (unmetered) air to enter the stream, particularly when the throttle is throttling the flow (higher ΔP). That will dilute the mixture, necessitating richer jetting to compensate. But of course the proper solution is to prevent 'false' air, as you did.
Btw, the optimal jetting will also depend on the exhaust, so you may have to re-visit when another muffler is fitted.
Users browsing this forum: Bing [Bot] and 27 guests
