New TS125 owner
Re: New TS125 owner
Postby Puffs » Wed Nov 24, 2021 8:01 am
Re: New TS125 owner
Postby Gerryman Ts125 » Wed Nov 24, 2021 2:58 pm
standard silver Nickel, TS exhaust. Maybe your has been painted. Should affect the performance. See you have a non Mz front hub. Is it Japanese. Maybe more shoe surface and a much better and thicker lever/cable size at the shoe end. Or is it a dual linked lever. As I cannot see it. :smt005
Gerryman Ts125
Re: New TS125 owner
Postby AndyP66 » Wed Nov 24, 2021 3:12 pm
I understand the front wheel is a complete Honda one. I believe it does give better braking. I do have the original TS one which I will be selling if anyone needs one.
The exhaust was already painted black when I got the bike. I also think the handle bars are different too.
I will be honest and I know it may upset some people on here, yet the plan is to paint the bike WW2 German grey and make it look a little older than it is. I want to change the handle bars to a wider set if possible and change the seat to a single one, if that’s possible also. Then have a paneer rack for the back to go over the rear wheel arch.
AndyP66
Re: New TS125 owner
Postby Gerryman Ts125 » Wed Nov 24, 2021 3:25 pm
Do as you please , I don't know if any Mz owners on this forum are purist's. ( I'm not) With a Mzs of any type, you just use what's handy or availble.
I have used lots of parts on my Mzs (don't have one now) that Mz never sold (mostly Japanese) So whatever you do should be suitable to you. As it's yours. :lol:
Gerryman Ts125
Re: New TS125 owner
Postby AndyP66 » Wed Nov 24, 2021 3:52 pm
Gerryman Ts125 wrote:Do as you please , I don't know if any Mz owners on this forum are purist's. ( I'm not) With a Mzs of any type, you just use what's handy or availble.
Thanks for the positive feedback.
I do BBC a lot of WW2 living history, mostly US or british RAF but I fancied putting a small display together for a German dispatch rider. As I don’t have a full bike licence this was the next best thing.
As anyone ever tried fitting a springer seat to a TS
AndyP66
Re: New TS125 owner
Postby Puffs » Thu Nov 25, 2021 6:15 am
Re: New TS125 owner
Postby AndyP66 » Sun Mar 27, 2022 3:50 pm
Firstly, the transformation is almost complete as you can see from the picture below.
But I do need to replace the clutch cable and possibly the throttle cable. Can anyone point me the right direction to purchase these.
AndyP66
Re: New TS125 owner
Postby Puffs » Mon Mar 28, 2022 3:04 am
Re: New TS125 owner
Postby AndyP66 » Tue Mar 29, 2022 4:17 am
Thanks for the link, will be ordering a few bits this week
Understand it’s not everyone’s taste, and to be honest I have kept all the bits I have taken off it so I can build it back to how it was. I do have a spare front wheel which I will be selling soon.
AndyP66
Re: New TS125 owner
Postby Gerryman Ts125 » Tue Mar 29, 2022 8:59 am
Clutch cables your on your own. They (TS 125 - 150 clutch cables) can be sourced on eboo or Amazonian.
As for throttle cables. I purchased a cheap cable off on eboo. It cost me £1:75 Inc p&p. I had to drill the original throttle housing (used a 6mm then 8mm drill to widen the slot the original cable went through) then tapped it. So I could take up the slack. The other end fitted straight into the carb and it worked grand. And I could adjust it at both ends. It was for a mini Moto. :smt006
Gerryman Ts125
Re: New TS125 owner
Postby AndyP66 » Fri Jun 17, 2022 1:47 pm
So I have finally got the time all next it very little to change the throttle cable. The manual I have does tell you how to remove the old one from the throttle lever.
Can anyone point me in the right direct please.
AndyP66
Re: New TS125 owner
Postby Puffs » Mon Jun 20, 2022 2:36 am
Re: New TS125 owner
Postby AndyP66 » Mon Jun 20, 2022 2:44 am
I can remove the cable from the carb. But I can’t see how to remove it from the hand throttle.
AndyP66
Re: New TS125 owner
Postby Puffs » Mon Jun 20, 2022 5:16 am
Re: New TS125 owner
Postby AndyP66 » Mon Jun 20, 2022 5:37 am
Thank you. Will have a look tonight.
AndyP66
Users browsing this forum: No registered users and 66 guests
