Puffs wrote:I'm not sure what a 24N2 carb is, possible a later version of the 24 N 1-1 & similar to that.
The manual prescribes the 22 N 1-3 for the TS125 & ES125, and the 24 N 1-1 for the TS150 & ES150, the latter with a 24mm venturi, vs. 22mm for the former.
In the Spareparts list (Ersatzteilkatalog für die Motorräder TS 125 und TS 150) the two share the same pic: And seem to differ only in body & jetting.
However, for the intake manifold different models are specified: 12-42.021 for the 125, and 14-42.025 for the 150; probably the mouth of the 24mm carb is a bit bigger.
You might get away with using an adapter (possibly just a d=1mm piece of alu??), but jetting may be impacted by the smaller intake manifold & also require adaptation. And if you don't make & seal that adapter properly you'll have false air. So maybe better also buy the proper intake manifold.
Are you sure the high idle issue will be solved with a different carb? For instance, have you found a clear problem in the old one, like a crack, or very significant wear, or so? Surely you can make the 125 run well with a 24mm carb, but you may have to adapt the jetting & other things, and chances are that your problem is not actually due to the carb (in the sense that there may not really be anything wrong with it).
What results did the earlier suggestions have?
Puffs wrote:Well, I have no experience with these carbs, and they may or not have that pin/groove. True, flat slide Mikuni & Keihin don't either, but round slides normally do.
To get clarity on this issue, I had a look at the original manual on Miraculis.de, as well as in the "MZ_TS125-150-1983-Official_Service_Manual.pdf", which both give a long section on it (Chapter 6, which I wholeheartedly recommend you read). The slide does look quite cylindrical though, and fig./Bild 124 does appear to show a groove. But it's not a clear picture.
Note there is a long section on how to use & set the starting feature, by rotation of the throttle handle.
Users browsing this forum: No registered users and 64 guests
