Steering Damper
Steering Damper
Postby lavrentyuk » Fri Jan 27, 2023 11:38 am
I am less than convinced of the efficacy of the friction steering damper that I now have for the Squire Dart fitting on the headstock - it seems to do nothing, or too much. What steering dampers are folk using with sidecars? How are you mounting them? UK links especially preferred.
I shall post some photographs of the set up once complete - for our reference.
With thanks,
RIchard
Richard Marshall
Wales, U.K.
lavrentyuk
Re: Steering Damper
Postby ScotBob » Sat Jan 28, 2023 12:26 pm
I had this on my TS250 combo:
ScotBob
Re: Steering Damper
Postby lavrentyuk » Sat Jan 28, 2023 4:34 pm
Seems to be the way I'm leaning.
Richard Marshall
Wales, U.K.
lavrentyuk
Re: Steering Damper
Postby mr_luke » Mon Jan 30, 2023 3:35 am
Do you have any photos of what you've got, Richard? Friction steering dampers are certainly not state of the art, but they can work fairly well, and the ability to adjust it is useful.
One thing to watch is to make sure there is no free play between the "fixed" portion of the damper and where it locates on the frame (or sidecar fitting in your case) as the presence of any undamped movement in the straight-ahead position will mean you need to run the damper even tighter to compensate.
If I remember correctly, the adjusting nut (obviously on the bolt which passes through the top and bottom yokes) bears against the fixed plate which is located on the sidecar fitting. In operation, this means the nut has to rotate in relation to the fixed plate which can lead to additional friction which is difficult to control. I fitted a thrust washer assembly here, consisting of a well-greased bronze washer sandwiched between two steel ones. If the bolt is long enough, you might find a needle roller bearing works well: https://uk.rs-online.com/web/p/roller-bearings/1999805?
mr_luke
Re: Steering Damper
Postby lavrentyuk » Mon Jan 30, 2023 9:52 am
Interesting, and thank you. The fixed plate does indeed locate on a ruddy great post on the big sidecar fixing bracket beneath the headstock - and I was having precisely the problem you describe. I may have another play with it yet then.
Richard Marshall
Wales, U.K.
lavrentyuk
