how to access Saxon Tour air filter -- help!
Postby LongRanger » Tue May 23, 2023 4:29 pm
I have a 1995 Saxon Tour and cannot for the life of me figure out how to access its air filter, covered by panel on left side of the bike which I can't see how to remove! It *appears* to have two flat-head screws at the bottom of this cover which screw in from the *back* (right side) and are virtually inaccessable, even with a right-angle ratcheting driver. Any tips or suggestions would be very, very appreciated; you can email me at <dcommprgr@gmail.com>. Many thanks in advance for any help!
LongRanger
Re: how to access Saxon Tour air filter -- help!
Postby DAVID THOMPSON » Wed May 24, 2023 7:53 pm
you have to go in from the battery side (right) its behinde the battery
the filter that work is the one bmw chopper late montock ?? with a home made adaptor
view very thin in this post
clicking on pictures will let you view my post of adapter for chopper filter
my part is down the linked page bit
ADPT INFO FOR FILTER
viewtopic.php?f=19&t=3684
Postby LongRanger » Fri May 26, 2023 3:13 pm
Many thanks and a thousand karma points for your help, Dave. I had removed the battery and saw the one nut securing what I now know is the air filter access cover, but stubbornly persisted in my mistaken belief that access was from the left side. Once apart I was delighted to discover that the filter itself is actually in fine shape! Now pursuing another problem: the 15A fuse on the fuse block "blows" the instant the ignition switch is turned to "On". After a lot of checking with an ohmmeter found that disconnecting the 9-pin plug connecting the instrument panel (and nothing else) to the rest of the harness eliminates that behavior. Still trying to figure out where to go from here. Thanks again, and I hope you have a nice weekend. Cheers... /Steve
LongRanger
Postby breakwellmz » Mon May 29, 2023 10:15 am
DAVID THOMPSON wrote:you have to go in from the battery side (right) its behinde the battery
Like this? Ha ha. :D
Postby DAVID THOMPSON » Mon May 29, 2023 12:08 pm
the problem with most bmw choppers is they turn out real UGLY most of the time
the one above is better than most
DAVE
Users browsing this forum: No registered users and 61 guests
